What is the purpose of left hand cut router bits?
Forum topic by TopamaxSurvivor posted 01-27-2011 09:10 PM 8002 views 0 times favorited 22 replies Add to Favorites Watch
TopamaxSurvivor
18162 posts in 3547 days
01-27-2011 09:10 PM
Topic tags/keywords: left hand router bits reversible
What is the purpose of left hand cut router bits? Are there reversible routers?
22 replies so far
View ajosephg's profile
ajosephg
1880 posts in 3432 days
#1 posted 01-27-2011 09:29 PM
Looks like they are used in production machines like this CNC door edge mortising machine. It has two motors, one right handed rotation and one left hand. “The computer automatically selects the proper motor to cut into the door to eliminate chipout and then switches to the second motor, if necessary, to prevent chipout at the other end of the cut.”
I didn’t know this until you asked and got my curiosity going. So, I learned something today.
-- Joe
16272 posts in 4090 days
#2 posted 01-27-2011 09:30 PM
From the Tyler Tool website:
Left hand cutters are used in routers that can run in reverse for special applications. Left hand cutters are most often used in industrial applications. Requires left arbors.
View Dez's profile
Dez
1166 posts in 3949 days
#3 posted 01-27-2011 09:30 PM
I’ve never seen one although they could be used in a shaper, most are reversible.
-- Folly ever comes cloaked in opportunity!
View JuniorJoiner's profile
JuniorJoiner
482 posts in 3311 days
#4 posted 01-27-2011 09:42 PM
the use I can think of is if you have a combo jointer planer machine that has the horizontal morticing attachment, the drive is off the jointer head, thus would be cutting opposite of a normal router.
-- Junior -Quality is never an accident-it is the reward for the effort involved.
View degoose's profile
degoose
7227 posts in 3226 days
#5 posted 01-27-2011 10:37 PM
You are all wrong …. they are for use down under….
TopamaxSurvivor
#6 posted 01-27-2011 10:40 PM
Sheesh!! I should have known that :-)
13594 posts in 3212 days
#7 posted 01-27-2011 10:49 PM
larry
so at the equator
they can’t use routers
as the bits don’t cut in either direction ?
View jim C's profile
jim C
1472 posts in 2970 days
#8 posted 01-27-2011 11:18 PM
your all wrong. They’re for putting the wood back on.
View Dan Lyke's profile
Dan Lyke
1519 posts in 3996 days
#9 posted 01-28-2011 12:01 AM
david, at the equator they’re reduced to just using planes.
View tyskkvinna's profile
tyskkvinna
1310 posts in 2857 days
#10 posted 01-28-2011 01:45 AM
I use left-hand router bits on my CNC router fairly often.
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
View rogerw's profile
rogerw
262 posts in 2561 days
#11 posted 01-28-2011 01:46 AM
larry- the blades are straight out for use on the equator. lol.
I have often pondered on the question about toilets on the equator. the northern hemisphere the water goes ccw and down under it goes cw. Does it just go straight down on the equator???
I once worked with a girl that went to australia on vacation for two weeks. i asked her when she got back about the toilets. she said she never paid any attention. WHAT !? That would have been the first thing i would have done when i got off the airplane! go find the bathroom!
-- >> my shop teacher used to say "do the best at everything you make for your mom because you're going to see it for the rest of your life!" <<
View Justin's profile
Justin
119 posts in 2840 days
#12 posted 01-28-2011 02:00 AM
I know with line boring machines there is a left and a right hand bits (orange and black bits)Line Boring Bits but i never had any experience with left handed router bits or slot mortising bits.
View ND2ELK's profile
ND2ELK
13495 posts in 3645 days
#13 posted 01-28-2011 03:21 AM
My Shaper can use router bits and has a forward and reverse motor. Sometimes running a piece of wood in a different direction might prevent tear out, and a smoother/safer feeding of a piece.
-- Mc Bridge Cabinets, Iowa
View oluf's profile
oluf
260 posts in 2910 days
#14 posted 01-28-2011 03:22 AM
Don’t forget the Dewalt radial arm saws that used a router bit adaptor on the motor shaft for overhead routing.
-- Nils, So. Central MI. Wood is honest.Take the effort to understand what it has to tell you before you try to change it.
TopamaxSurvivor
#15 posted 01-28-2011 04:10 AM
I don’t think i have ever heard of a small router with a reverse. Has anyone else? They must be just for CNC and other larger machinery, eh?
