Painting over polyacrylic
Forum topic by rwe2156 posted 09-18-2017 08:36 PM 362 views 0 times favorited 4 replies Add to Favorites Watch
View rwe2156's profile
rwe2156
2964 posts in 1505 days
09-18-2017 08:36 PM
This is on kitchen cabinet doors with typical ogee rail treatment and flat panels with grooves. The client wants to keep existing doors if possible.
I’m thinking wipe down with naptha and use wb base primer.
Sanding out of the question too time consuming. I’ve thought of stripping the doors they are hickory with just poly no stain.
Thx.
View barada83's profile
barada83
86 posts in 1211 days
#1 posted 09-20-2017 02:46 AM
Nah- Bad idea. I just tried that with an epic fail. Had to sand off the new finish that was coming off with my fingernail. I would do a scuff sand with 120 grit. Just get some scratches. Then hit it with shellac primer. I used Sherwin willaims. Test for adhesion before painting. If the primer sticks, you are good to go. The shellac dries super fast.
-- Mike
117115 posts in 3602 days
#2 posted 09-20-2017 04:46 AM
I agree with Mike but I would use 180 grit.
rwe2156
#3 posted 09-20-2017 02:44 PM
Ok sanding is a must what about the ogee moldings and corners of the panel?
I’m thinking start from scratch that way I can paint the panels separately the whole job will look better.
View OSU55's profile
OSU55
1699 posts in 2014 days
#4 posted 09-20-2017 04:05 PM
An option for the mouldings would be scotchbrite to scratch them, but buying new, out any material since you are painting, may be best option.
