Unifence Repair
Forum topic by ChefHDAN posted 09-18-2017 08:15 PM 492 views 0 times favorited 4 replies Add to Favorites Watch
View ChefHDAN's profile
ChefHDAN
1193 posts in 3055 days
09-18-2017 08:15 PM
Hey LJ’s looking to see if any or all can help me with getting this unifence repaired so that I can put on a new scale and have the cursor function properly. I got it free off of Craig’s list and jumped before realizing the scope of repair needed. The cast aluminum frame for the cursor is cracked off and gone, there is a bit of the plastic cursor still screwed to it and I’m wondering if that could just be replaced without the frame??? I have no great ideas and hope to draw on the wisdom & experience here, thanks for taking a crack at a solution to help me!
View ErichK's profile
ErichK
80 posts in 869 days
#1 posted 09-18-2017 08:29 PM
The frame doesn’t look functional at all besides protecting the pointer from being broken. I suspect that attaching a new pointer would cause no problems and restore functionality.
That said, adding a new frame is something that would be doable for someone with access to a milling machine (or just patience and files).
View Ripper70's profile
Ripper70
1165 posts in 1114 days
#2 posted 09-18-2017 08:46 PM
I’d recommend getting yourself a Wixey WR700 digital readout. It’ll solve your problem and your fence will be more accurate than ever.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
View Scott's profile
Scott
116 posts in 1561 days
#3 posted 09-19-2017 12:16 AM
It doesn’t look like you need anything except for a new cursor. Item 18 on the link below. Just screw it on and go. If you wanted to protect it on the one side you could always drill and tap it and bolt on a bracket. Good luck!
http://www.toolpartsdirect.com/rockwell-36-902-30-quot-unifence-with-rail.html
ChefHDAN
#4 posted 09-24-2017 02:22 PM
Scott, thanks for the lead, unfortunately, when i tried to buy it was obsolete and not available for sale, still searching
