Maple Dining Room Table
Forum topic by tjbisme posted 09-18-2017 07:51 PM 1067 views 0 times favorited 21 replies Add to Favorites Watch
View tjbisme's profile
tjbisme
26 posts in 482 days
09-18-2017 07:51 PM
I’m going to be making a dining room table out of Maple for a family member and I’m trying to find the best way to finish the wood. My plan was to use some Minwax Polyshades Royal Walnut stain for the table top, and then put Minwax One Coat Polyurethane over the top of that to help protect it. I was wondering if this is a good idea, or will I be asking for problems when trying to finish this project? Also, will the poly yellow over time as I have read on some other sites?
Thank you in advance!
-Trevor
21 replies so far
View Loren's profile
10477 posts in 3764 days
#1 posted 09-18-2017 07:59 PM
Maple can be tricky to stain well. You might
look into dyes. Colored maple guitars are typically
sprayed with tinted lacquers to get that transparent
“candy apple” look. If you want that, look
at dyes. Maple can look kind of dirty when
stained, imo.
Whatever you do, run some finish tests before
staining the whole table.
View martyoc's profile
martyoc
44 posts in 1033 days
#2 posted 09-18-2017 09:25 PM
I agree with Loren that using dyes is the best approach. I have used stains on a few projects with maple and was never completely happy with the result. I used water based dyes on a pair of large maple dressers a few years ago and made several test pieces beforehand to get the coloring to satisfy our tastes – something quite easy and quick to do with dyes.
-- Marty O'C
View Aj2's profile
Aj2
1654 posts in 1914 days
#3 posted 09-18-2017 09:29 PM
Good luck trying to make maple look like walnut. Better off just buying walnut
-- Aj
View Kirk650's profile
Kirk650
543 posts in 864 days
#4 posted 09-19-2017 12:04 AM
Aj2 is right. I made a blanket chest for a niece and decided to use Maple. Really bad idea. Finally I got it to look good by using Charles O’Neils blotch controller and trans tint water soluble dyes. Made it look like walnut. Woulda been easier to just buy the danged walnut. That was a real tough job, with many many test boards and stains. Final finish was Waterlox.
I think the dye combo I used was Transtint Coffee Brown, followed by Transtint Dark Walnut, with just a touch of J E Moser Dark Wine Cherry.
You can do it, but it won’t be a quick job.
tjbisme
#5 posted 09-19-2017 12:16 AM
I guess I should clarify I’m not trying to make it look like walnut, that’s just the color brown she wanted and that’s what the stain color is called. If there is a dye that is close to that color, I think that would be just fine.
I was reading somewhere the gel stains work out ok on maple, what’re your opinions on that? Or what about using a wood conditioner that goes on before a stain?
Thanks,
Trevor
View AlaskaGuy's profile
AlaskaGuy
4353 posts in 2425 days
#6 posted 09-19-2017 12:46 AM
If I wanted a walnut looking table I’d build it out of walnut. Why buy a very light colored wood just to turn it dark with stain or dye.
Kirk650
#7 posted 09-19-2017 12:50 AM
The O’Neil’s blotch controller (my term) is a wood conditioner. It greatly reduces, if used properly, the nasty blotching you’ll see with maple.
I tried every stain and dye type I had on that maple, but it was the water soluble Transtint that finally worked. In sequence:
Blotch controller/wood conditioner
Coffee brown dye
Walnut dye (applying the wet dye removed a bit of the coffee brown dye, which was a good thing)
Watco Danish Oil (clear), and let dry 3 days)
Very very lightly sand, 600 grit, since the Watco held in place any raised grain, but don’t remove stain.
Waterlox application 1 ( looked awful)
Waterlox app 2 (looked better)
Waterlox 3 ( looked pretty darn good)
Waterlox 4 (looks good, I’m done).
Took me maybe a month to figure out the finish. Drove it to Tennessee to give to niece’s little girl. Little girl climbs up on top of chest and dances with shoes on. I almost fainted. Waterlox held up just fine.
View OSU55's profile
OSU55
1830 posts in 2105 days
#8 posted 09-20-2017 04:23 PM
I would not use mw polyshades anything on any project that was to look even decent. As others said, dyes are the way to go. I prefer Transtint in Target WR4000 stain base, tthe oile emulsion provides grain pop or chatoyance. Definitely want to condition maple for coloring – here is some info.. Cant comment on the mw one coat- no experience. I think thats their oil modified wb. GF has a wb poly thats popular, I prefer Targets EM9000. A shellac seal coat over a wb or alcohol stain/dye should be used with a wb topcoat to prevent lifting. OB poly/varnish it isnt a concern.
View CharlesNeil's profile (online now)
CharlesNeil
2434 posts in 3986 days
#9 posted 09-20-2017 04:32 PM
Polyshades is one of the worst products out there IMO.
View johnstoneb's profile
johnstoneb
2999 posts in 2289 days
#10 posted 09-20-2017 04:37 PM
Charles that is my opinion also. I used it once and never again.
-- Bruce, Boise, ID
tjbisme
#11 posted 09-20-2017 05:13 PM
Thank you everyone for the tips. I definitely have my work cut out for me and I’ll be sure to do some testing to ensure i get the right look.
As far as the polyshades is concerned, I’m wondering what the drawback is to it? I’ve used it before on some of the projects I’ve completed, and it looks pretty nice when finished, of course it’s been all pine, but it seems to look alright to me. I’m very new to this as well, so I guess I want to know from you as to why you dislike MinWax’s Polyshades so much? I believe the MinWax OneCoat is oil based water modified.
Thanks again,
Trevor
View mahdee's profile
mahdee
3970 posts in 1883 days
#12 posted 09-20-2017 05:24 PM
- CharlesNeil
-- earthartandfoods.com
View jonah's profile
jonah
1835 posts in 3414 days
#13 posted 09-20-2017 05:46 PM
Count me in the group that hasn’t had good results with Polyshades. There are a lot of other, better options out there.
I’ve also never successfully stained maple. As others have mentioned, dyes are the ticket there.
CharlesNeil
#14 posted 09-20-2017 06:05 PM
I agree dyes are the way to go, with a good prestain, but dyes are a completely different animal than stains, here is a video I did that will explain, some https://www.youtube.com/watch?v=zgFzzZd0JVI&t=220s
Also here is a blog I wrote, about using dyes over our prestain but would apply to any I would think, it explains more about pre stains https://intheworkshop.wordpress.com/2012/04/17/applying-dyes-stains-over-my-blotch-control-prestain/
Experience has shown that water base prestains do better under water base dyes ,IMO
View Monte Pittman's profile
Monte Pittman
29786 posts in 2454 days
#15 posted 09-20-2017 06:21 PM
1+ what Loren said
1++ What Charles said
