Planer question
Forum topic by Jeff82780 posted 01-27-2011 07:54 AM 1191 views 0 times favorited 9 replies Add to Favorites Watch
View Jeff82780's profile
204 posts in 2925 days
01-27-2011 07:54 AM
Well, I just purchased my first planer on CL for $120. It’s a 12” Jet. Looked like a great, but now maybe not. I tested it out at the guys house on some 1x oak and planed the piece nice and smooth. Well, when I brought it home to run some more test piecesof pine through it, I noticed that little scrapes and dents were in the wood. I figured I just needed some new blades. well, I bought some new blades and there is no difference . Still nicks and dings in the wood.What gives????? The only other thing I can think of is that the roller that has the blades in it, has some surface rust?? Maybe thats it? What do you LJ’S think the problem is???
9 replies so far
View wseand's profile
2796 posts in 2973 days
#1 posted 01-27-2011 08:54 AM
Is this happening in one area or all over the planer. If you plane a board straight through you can kind of tell where the problem is by looking at the board when it come out. Mark the planer with a pencil where the scratches are so you can reference where to start looking for a problem, if that makes sense. I would give her a good thorough cleaning. Look at the rollers, clean them off and see if there is a problem somewhere on it. Check to make sure if there is anything hanging down. Look at where the blades are and make sure there is nothing that the blades might be hitting and getting dinged. In my experience if the blade has a ding in it, it will leave a raised mark on the wood all the way down the wood, not a nick or a ding.
View twoblacklabs's profile
253 posts in 2622 days
#2 posted 01-27-2011 09:59 AM
I suspect you have debris on the rollers.
-- If You Haven't Got the Time to Do It Right, When Will You Find the Time to Do It Over?
View Loren's profile
10081 posts in 3579 days
#3 posted 01-27-2011 11:04 AM
Look at the grain direction of the wood you’re planing. If you plane
“uphill” you’ll often get chipping.
View mstenner's profile
57 posts in 3085 days
#4 posted 01-27-2011 02:59 PM
You might also not be clearing chips well enough. When I plane without dust collection turned on (by accident, plug the wrong hose in, etc) I get dents and dings. I suspect chips are getting caught between blade and wood, and get smashed into the wood. I would expect pine to be more susceptible to this than oak.
-- -Michael
View Gene Howe's profile
Gene Howe
10252 posts in 3359 days
#5 posted 01-27-2011 03:36 PM
Feed rollers are dirty.
#6 posted 01-27-2011 04:01 PM
the marks are all over the board, not in one area. i dont have a dust collection yet. so maybe the chips getting caught inside is the problem. i will also check the feed rollers.
View FatScratch's profile
189 posts in 3234 days
#7 posted 01-27-2011 04:38 PM
I agree with all the previous posts, but also add that a piece is rarely “finish” ready when it comes out of the surface planer. I also get this a lot in pine, more so than hardwoods.
#8 posted 01-27-2011 09:59 PM
thanks everyone! I connected my shop vac to the planer and cleaned the rollers. Now everthing seems good. hopefully it stays that way
View dbhost's profile
5687 posts in 3163 days
#9 posted 01-27-2011 10:21 PM
Since you got it figured out, this might not help much, but to summarize this…
#1. Make sure you are collecting the dust / chips from this. That stuff gets between the wood and the cutter and makes a mess of things. #2. Make sure your feeding with the grain, and not against so that you don’t chunk out the grain with the cutter head. See Marc Spagnolo’s The Jointer’s Jumpin video for tips on that. Yeah jointing and planing have a LOT of the same issues…
-- My workshop blog can be found at, YouTube Channel
