Milling wood
Forum topic by caboxmaker posted 09-18-2017 07:21 PM 667 views 0 times favorited 11 replies Add to Favorites Watch
View caboxmaker's profile
caboxmaker
281 posts in 413 days
09-18-2017 07:21 PM
I have read about the term “FEE” when referring to milling lumber prior to building a project. “FEE” stands for face, edge, end. Can someone tell me how that works and the equipment required? Please only respond if you have actually used the “FEE” approach to milling.
11 replies so far
View Firewood's profile
Firewood
342 posts in 1659 days
#1 posted 09-18-2017 07:40 PM
F=flatten a face of the board. This is typically done with a jointer.
E=square one edge with the flattened face. This is also done with the jointer.
E=ends can now be cut square to the face and edge.
With that being said, you still need to dress the other face and edge. This cannot be done with the jointer. The second face should be done on a planer and the opposite edge can be done on a table saw. This keeps all faces and edges square and parallel.
Also, first step should be to cut the rough stock to a couple inches over desired length to minimize stock removal during jointing and planing.
-- Mike - Waukesha, WI
View jdh122's profile
jdh122
1018 posts in 2842 days
#2 posted 09-18-2017 07:52 PM
As it’s described here (http://www.finewoodworking.com/2005/09/12/all-about-milling-lumber) just about all woodworkers follow this method. Indeed I can’t really imagine another way to do it. I suppose that some of us joint the face and one side before planing and some of use joint one face, plane the other and then joint one edge (in both cases you then use the tablesaw as the final steps). Not much difference between the two orders, other than the fact that the second allows you to choose feed direction when you joint the first edge.
Normal tools are jointer, planer and tablesaw, although all kinds of workarounds exist to get by without one or the other of these three tools.
Quote from article:
“Follow the “FEE” system
Work the faces, then the edges, and finally the ends (“FEE”). This order is exactly the opposite of the rough milling process. Start at the jointer and flatten one face of the board. Then run the board through the planer with the jointed face down to create a parallel, flat opposing face. After the faces are flat and parallel, work on the edges. Back at the jointer, run the board on edge until it is square to the face. The last edge is cut parallel to the jointed edge on the tablesaw. Finally, crosscut the ends to length. If the board won’t get put to use immediately, keep it stickered so it retains its four-square shape.”
-- Jeremy, in the Acadian forests
View papadan's profile
papadan
3584 posts in 3393 days
#3 posted 09-18-2017 08:18 PM
- caboxmaker
All of us that buy rough sawn lumber use the “fee” system, just never heard that name for it. I plane my faces, Use a router and straight edge the joint one edge and use the tablesaw to cut the opposite edge and cut to length with a crosscut sled. Just normal operation.
View ColonelTravis's profile
ColonelTravis
1800 posts in 1919 days
#4 posted 09-18-2017 08:28 PM
What other approach is there?
papadan
#5 posted 09-18-2017 08:34 PM
I always thought the “FEE” approach was when you pay someone to mill your lumber. ;-)
View DS's profile
DS
2925 posts in 2445 days
#6 posted 09-18-2017 08:35 PM
The typical approach is as already stated. Though, this is the first time I’ve heard it called “FEE”.
- ColonelTravis
There’s always other approaches. e.g. Feed rough-sawn through the gang rip (for straight line and rough width), then through the 5-head molder = instant S4S lumber (In volume and with a profile, if desired).
Most folks don’t have that kind of equipment in a home shop (I sure don’t).
View rwe2156's profile
rwe2156
2964 posts in 1505 days
#7 posted 09-18-2017 08:38 PM
The principle is to establish a flat face and a straight reference edge in order to mill the lumber to thickness and width.
Equipment needed: jointer and planer.
The width of each depends on how wide you want to be able to joint. An 8” jointer and 15” planer will get you pretty far.
caboxmaker
#8 posted 09-18-2017 08:54 PM
- papadan
Papadan, did you read that somewhere?
papadan
#9 posted 09-18-2017 08:59 PM
- papadan
- caboxmaker
Nope, and never paid to get wood milled either. LOL
woodbutcherbynight
4843 posts in 2434 days
#10 posted 09-19-2017 01:43 AM
Never knew this process was called something. I assumed it was the way of things. Whether it be using hand tools or power tools the end result is dimensional lumber that is flat and square. Who knew?
For me a FEE is what I charge someone when on a rare occasion I agree to make something for them. The amount depends on how much of a pain in the %^& they were throughout the process. Sometimes it is referred to as exorbitant.
LOL
View Lazyman's profile
Lazyman
2050 posts in 1412 days
#11 posted 09-19-2017 02:01 AM
While the jointer is the easiest way to get the first face and edge flat and square (FE), you can also do it with a router jig (for the face) and a table saw jig to get the first edge straight and square. If you only need to do this occasionally, this is a much cheaper way without buying a jointer, though much more time consuming. Of course the old school method is to use hand planes.
