steam bending some quartersawn air dried red oak
Forum topic by dorran posted 01-27-2011 07:18 AM 5942 views 0 times favorited 13 replies Add to Favorites Watch
View dorran's profile
dorran
140 posts in 3434 days
01-27-2011 07:18 AM
Topic tags/keywords: steam bending question
I am getting ready to steam bend some chair back slats for a Morris chair. The plans call for a 36” radius bend. I made a form with a 34” radius to allow for some spring back. My question is how long to do I have to keep the wood in the form? I only made 1 form and would like to steam all the slats at the same time. Will the spring back diminish after initial cooling (5 minutes) or does it have to be held until it is dry again(hours, days, weeks, months, years)?
Thanks for any experience with this.
Dorran
-- Life is about choices. You can spend a lot of money on furniture and have really nice furniture; Or you can spend a lot on tools and have even more expensive, crappy furniture. I made my choice.
13 replies so far
View richgreer's profile
richgreer
4541 posts in 3274 days
#1 posted 01-27-2011 03:50 PM
I have not actually done this but I have seen several videos on the subject. It’s my understanding that you need to leave the wood in the form until it drys completely. That could be more than a week.
dorran
#2 posted 01-27-2011 05:09 PM
OK. Thanks. The bend didn’t seem all that extreme so I thought it could be less. The wood is 3/4” thick. Maybe I need more forms or another way to hold as it dries.
View tbone's profile
tbone
276 posts in 3884 days
#3 posted 01-28-2011 09:11 PM
I’ve only bent white oak, but I always leave it clamped in the form about 24 hours. Naturally, there is some springback immediately. However, it could spring back a little bit more over the next couple of days. Once it quits moving, it will stay that way from then on.
By the way, I think curved backslats on that Morris chair is a tremendous improvement in comfort.
Good luck.
-- Kinky Friedman: "The first thing I'll do if I'm elected is demand a recount."
View TheDane's profile
TheDane
5548 posts in 3863 days
#4 posted 01-28-2011 09:32 PM
Dorran—I would go for more forms and longer dry time.
When I built my Morris Chair, I left the red oak stock clamped in the form for 7 days … had minimal springback.
—Gerry
View Howie's profile
Howie
2656 posts in 3123 days
#5 posted 01-28-2011 11:38 PM
you could leave it in the form and use a heat gun to expidite the drying. I do that all the time.
-- Life is good.
View shipwright's profile
shipwright
8166 posts in 2998 days
#6 posted 01-29-2011 06:45 AM
You could also let it cool in the form and then, since it’s an even radius, just string it like a bow while it dries out. The initial bend stretched and pulled the fibers. Now all you’re doing is preventing them from returning, a much lesser force is required.
dorran
#7 posted 01-29-2011 06:56 AM
Thank you all for the very good advice. I will make some more forms for holding the shape, wait at least 24 hrs, and try a heat gun if I get impatient. Now I just have to wait for the cold and snow to go away.
View Loren's profile
10477 posts in 3848 days
#8 posted 01-29-2011 08:14 AM
Bend the slats into the form and hit them with compressed air – helps
set the bend (luthier trick). Then take them out and put them in a
drying form that overbends them a bit.
Leave the wood in the forms for quite a while. I saw a shop where the
guy had drying forms all over the walls. They were pretty simple but
held the bends all in the same shape. Presumably he bent more than
he needed and used the ones that matched up best.
If you bevel the 4 edges of each piece a little it can help prevent splitting.
Howie
#9 posted 01-29-2011 02:57 PM
Loren, learned another trick..thanks
-- Life is good.
View tenontim's profile
tenontim
2131 posts in 3944 days
#10 posted 01-29-2011 03:13 PM
I leave my pieces in the forms for several days until dry. You don’t have much time for getting the bend if you’re using kiln dried wood. Set everything up to get the piece bent as quickly as possible. The quicker it’s bent, the less spring back you’ll have. I get mine from the steamer and clamped in the form in about 10 seconds. Air dried wood is better for bending, if you can get it, and you have about 10 minutes to bend it. That’s the way I do it.
dorran
#11 posted 03-09-2011 08:22 AM
Steamed today with some success. I built a bending form and a drying rack/form. My set-up took a long time to get up to temperature. I ran the grill for 7 hours total to boil a few gallons of water. 6 back slats loaded 3 at a time in a 4” pvc pipe. The other snag was the steam swollen wood got stuck in the pvc steam chamber. Lesson learned. If it’s snug going in cold, it won’t come out hot.
Thanks for the help.
Dorran
tbone
#12 posted 03-10-2011 11:29 PM
Good job dorran!
You can shorten the time it takes to get to the boiling point if you first heat it up on the stove in the house.
My set-up is a length of 6” PVC pipe, a Coleman camp stove, and an UNUSED steel gas can with a radiator hose connecting the can to the steam chamber. (If the Homeland Security boys ever busted into my garage, I might have some explaining to do before they figured it out)
View misbeshavings's profile
misbeshavings
18 posts in 2844 days
#13 posted 03-17-2011 05:29 PM
where did you get your plans for the chair?
anyone got a favorite? I’m planning on a couple this spring, and can’t decide which plan I like best.
