Delta Unsaw
Forum topic by LarryE posted 09-17-2017 02:14 AM 489 views 0 times favorited 7 replies Add to Favorites Watch
View LarryE's profile
LarryE
6 posts in 2033 days
09-17-2017 02:14 AM
I have a Delta Unisaw that I had for over 30 years, now the blade won’t say tight. Any ideas ?
Thanks
7 replies so far
View Kazooman's profile
Kazooman
1115 posts in 2070 days
#1 posted 09-17-2017 02:59 AM
First idea: give us a bit more to go on. “The blade won’t stay tight” doesn’t give us a lot to work with.
LarryE
#2 posted 09-17-2017 03:18 AM
Ok, I put the blade on the table saw arbor and tighten the nut up, as I’m cutting the blade loosen up.
View Floyd Hall's profile
Floyd Hall
121 posts in 389 days
#3 posted 09-17-2017 03:53 AM
Threads on the arbor could wearing out or the nut that holds the blade flush to the flange could be wearing out. I’d go with the latter first.
View Aj2's profile
Aj2
1658 posts in 1916 days
#4 posted 09-17-2017 04:29 AM
Is it possible the saw is running backwards ? Maybe a bad start capacitor
-- Aj
LarryE
#5 posted 09-17-2017 04:46 AM
No Way!
View MrUnix's profile
MrUnix
6887 posts in 2317 days
#6 posted 09-17-2017 04:50 AM
Check your arbor flange/threads for crap… most likely you are not getting the blade fully seated initially. Truing up the flange and washer may help (see here). There really is no other way for it to ‘loosen’ up as the direction of spin causes the nut to tighten, not loosen.
View Aj2's profile
Aj2
#7 posted 09-17-2017 05:07 AM
Okay dokay. :)
-- Aj
