Using taper jig
Forum topic by opalko posted 847 days ago 1634 views 0 times favorited 16 replies Add to Favorites Watch
View opalko's profile
opalko
95 posts in 1206 days
847 days ago
I am making some simple legs for a nightstand that taper from about 5” from the bottom of the leg at a thickness of 1.5” to 1” at the bottom of the leg. Each leg is tapered on any inside face (so 2 faces for each leg). I am using this jig:
http://www.woodmagazine.com/woodworking-plans/jigs/super-simple-tapering-jig/
What I am running into are 2 problems:
  1. The top of the tapers are not perpendicular to the edge of the leg. They are more sloped so that one top corner of the taper starts higher than the opposite corner! I have double checked the blade and leg for square.
  2. This throws off the adjacent taper on the next inside face when the leg is turned 1/4 turn. If the previous face had a taper that sloped from say 6” to 5”, then on the adjacent face the taper will do the same thing and now a taper at 5” meets a taper at 6”!
It’s difficult to explain but obvious when you see a picture, which I’ll try to add later . But for now, you can sort of see it in this diagram which shows a very similar configuration to what I’m trying to do. On the back left leg you can see where I added 2 diagonal lines representing how the taper is ending up on my legs. Any ideas??
Cheers
Robert
16 replies so far
View jbell2355's profile
jbell2355
21 posts in 978 days
#1 posted 847 days ago
Just be mindful to cut the correct taper first. Think about how the leg will ride on the sled or fence after the first cut. As long as you cut the right one first you won’t have a problem.The alternative is to tape the cutoff back on, or use a little block that holds the foot of the leg in the correct position. Good luck.
-- She was only a rancher's daughter, but all of the horsemen knew her.
View TheDane's profile
TheDane
2675 posts in 1833 days
#2 posted 847 days ago
Are you taping the cut-off back on the leg after you cut a taper?
—Gerry
opalko
#3 posted 847 days ago
Not taping it back on. Should I be? Why?
TheDane
#4 posted 847 days ago
To maintain the same degree of taper, the stock needs to be approximately the same size on each cut. You can accomplish that by taping the cut-off back on. When I tape the cut-off back on, I adjust it to account for the material lost in the kerf.
If you cut a taper, then rotate the stock so the taper you just cut is either against the base of the jig or the fence, the angle of the first cut will effect the second cut and so on. Judging from your drawing, that is what appears to be happening to the rear leg.
—Gerry
opalko
#5 posted 847 days ago
Gerry, thanks, although I don’t think that is what is happening. When I cut one face only, the top of the taper is not square to the edge of the stock. I’ll take a photo of a single taper tonight to show here.
TheDane
#6 posted 847 days ago
Wow … that almost sounds like either the bed of the jig isn’t flat, or the blade isn’t true 90-degrees to the table.
—Gerry
14858 posts in 2388 days
#7 posted 847 days ago
...or the leg stock is not perfectly flat/square to begin with.
View Jim Finn's profile
Jim Finn
1066 posts in 1092 days
#8 posted 847 days ago
IF you want to make two tapers on the same leg I suggest you build and use the jig referred to in your link as an “adjustable taper jig” instad of the “Smple Jig”. I made one and it works well for me.
-- In God We Trust
opalko
#9 posted 847 days ago
I’ll check all of these things tonight and report back!
Thanks
View Richard's profile
Richard
503 posts in 860 days
#10 posted 847 days ago
That jig should work just fine if everything else is adjusted correctly, as long as your only doing a taper on 2 sides of the leg and not putting the 1st tapered side against the fence when you cut the 2nd one.
Richard
#11 posted 847 days ago
Here is a link to another adjustable jig here on LJ’s.
http://lumberjocks.com/projects/43377
TheDane
#12 posted 847 days ago
If you plan on doing a lot of tapered cuts, I don’t think you can beat the jig designed by Charles Neil – http://charlesneilwoodworking.com/references/taperjig.pdf
—Gerry
Jim Finn
#13 posted 847 days ago
I have made a jig that has a nail point to insert at the center point of the small end of the leg to be tapered . It is at the push point. I put the center of the leg on that nail point, clamp tight,cut one taper, and spin it to make the second cut. Works like a charm. I got the idea form a wood working ” on line magazine” but I do not remember which one. It has been over a year ago now. There was a video showing its use.
-- In God We Trust
View bobsmyuncle's profile
bobsmyuncle
105 posts in 861 days
#14 posted 847 days ago
Here is the best way I’ve found to make tapered legs. Dead simple.
http://www.popularwoodworking.com/article/Tapered_Legs_On_A_Planer/
View wseand's profile
wseand
1549 posts in 1212 days
#15 posted 847 days ago
I have switched to the joiner method. I have found it to be a bit more accurate and no setup and less sanding.
-- Bill - "Freedon flies in your heart like an Eagle" Audie Murphy
