Finishing a projectd before assembly
Forum topic by Redford1947 posted 846 days ago 677 views 0 times favorited 8 replies Add to Favorites Watch
View Redford1947's profile
Redford1947
35 posts in 979 days
846 days ago
Obvioulsy it would be easier to finiish all the parts of a project while they are flat on a table before assembly. However, I am concerned about damage when assemblying. What do you guys do? I am making a chest and it would be harder to sand, stain etc. when it is a box rather than flat pieces.
Appreciate any suggestions.
Redford
8 replies so far
27262 posts in 1991 days
#1 posted 846 days ago
Redford, I will generally finish the inside of my casework before assembly because, as you mentioned, it is easier to get to it- especially where the corners are concerned. I will mask off any areas that will come in contact with glue. And you are right the prefinished pieces may get scratched during the milling and assembly process. However, this is easier to correct, in my opinion, as opposed to trying to sand and apply finish inside of the cabinet.
View Jonathan's profile
Jonathan
2568 posts in 1219 days
#2 posted 846 days ago
I’d have to agree with both comments above.
It’s much easier to finish things, and finish them consistently when they’re flat, even when, and sometimes especially if, you’re spraying.Your corners and joints will tend to look better as you’ll have a more evenly applied finish if you finish the flat surfaces before assembly.
Not that you always have to finish things before assembly, as Barry says. With something like a chest though, you may get a better end result by finishing it first.
Try this: do a dry-fit with clamps, etc. Then imagine where you might have problems finishing it if you were to assemble it all first. Is it going to be more work to use tape and be extra careful when assembling, or is it going to be more difficult to get into all those tight spots and get an even coat of finish without missing anything, or applying too much, getting runs, etc.?
It also depends on the finish you want to apply.
-- Jonathan, Denver, CO "Constructive criticism is welcome and valued as it gives me new perspectives and helps me to advance as a woodworker."
View riverb's profile
riverb
45 posts in 843 days
#3 posted 842 days ago
i might try it on my next project. it will have a lot of smaller pieces. It sure would be nice to have them done before hand.
View mcase's profile
mcase
397 posts in 1298 days
#4 posted 842 days ago
I started pre-finishing with floating panels to avoid unfinished edges from appearing. I now do it all the time to virtually all my components. Its a lot easier when there are no corners. Another big advantage is that you can wipe glue squeeze out right off with a damp paper towel. No muss no fuss. You can still add glazes and effects after assembly too. To me its a win win situation.
View mtkate's profile
mtkate
2049 posts in 1494 days
#5 posted 842 days ago
Finish as much as possible first. It saves SO MUCH frustration. And like the guys say above. you can protect from squeeze out with blue tape, etc. etc.
Charles Neil did a great article in FWW recently enough about it. Here is the link to it:
http://www.finewoodworking.com/PlansAndProjects/PlansAndProjectsPDF.aspx?id=32986
View indianawoodbutcher's profile
indianawoodbutcher
34 posts in 858 days
#6 posted 842 days ago
I have been trying different techniques to cut the finish time. So far, pre-finishing is the best idea. However, one must be careful about what gets pre-finished, and what does not. Finishing pannels is a great idea. But to try to finish the rails and styles before assembly eliminates the ability to clean up the joints with a good bit of sanding. As far as the inside of projects, it all depends upon how much will be seen/touched. I try to be reasonable. If there is a piece that is not going to be seen, then I don’t give it a lot of attention. To some, that is lazy, to me it is working smart.
Redford1947
#7 posted 826 days ago
Appreciate all the suggestions. One question (a stupid one): does the glue stick, cure to poly surfaces or do I have to mask joints that will be glued?
View tyskkvinna's profile
tyskkvinna
1294 posts in 1155 days
#8 posted 826 days ago
The glue will absorb into the wood better if there is no poly on it. I personally would mask any areas that will be receiving glue.
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
