| Forum topic by Vasko | posted 844 days ago | 886 views | 0 times favorited | 10 replies | ![]() |
844 days ago |
Not sure I’m posting this in the right forum, but here goes; I have some black walnut that will need to be finished. I have a test piece I just played with – I put two coats of Watco on it. -- - Cindy, texture freak - |
10 replies so far
#1 posted 844 days ago |
I havent used oil paints, but it is common to use a sealcoat of shellac to seal the colors of your dye/stain combo. followed by whatever film finish someone wants whether more shellac or laquer, varnish, poly etc. Sounds like a cool project, look forward to seeing it. I would PM Shipwright – he has done a lot of coloring and staining so he could comment on compatibility -- "_If we did all the things we are capable of doing, we would literally astonish ourselves_." Edison |
#2 posted 844 days ago |
Thanks – -- - Cindy, texture freak - |
#3 posted 844 days ago |
DrDirt gives me a bit too much credit, but thanks. I am just experimenting with dye in marquetry but I think that to answer your question I could say that I’m pretty sure that oil based paints over an aniline dye would be fine. The dye could be smeared by a water or alcohol based product but I have wiped oil based poly over “watercolor style” dying and it doesn’t hurt the dye. I would however invite you to help me develop this style of dying. There’s a lot more to learn and from my internet searches, I can’t find anyone else that’s tried it. -- Paul M ..............If God wanted us to have fiberglass boats he would have given us fiberglass trees. http://prmdesigns.com/ |
#4 posted 844 days ago |
Hmmm, that’s interesting So this is what I’m thinking of; aniline dye on the walnut to bring out figure. Oil paint imagery over the dye. Oil based spar/uv poly over the whole thing to bring out the grain. The poly will have to be oil because the paints are oil. (I love oil based finishes anyway) -- - Cindy, texture freak - |
#5 posted 844 days ago |
I think the paint over the stain (if the stain were alcohol or water based) would be fine. If you have some scraps though, experiment with the color and finish. Spar poly tends to add its own color and due to the UV inhibitors tends to be a wee bit cloudier than other forms of poly. -- Galootish log blog, http://www.timberframe-tools.com |
#6 posted 844 days ago |
Ok, I’ll post a few pics, I warn you they’re fuzzy. I took them this morning before coffee – lol I have a post in a forum about tools, and what my priorities should be. Some posters have brought up an excellent and obvious (but not to me at the time) thought; I need to decide what I want to do, and get tools to do the job. So I have to spend some time thinking about what is is I really want to say with wood. All I have right now is a vague desire to meld my other art/craft skills into one unified project – hopefully a saleable one in time. The bottom pic is kiln fired slumped glass (can’t tell from the pic, but it is a shallow curved plate) 12” or so across. The middle pic is a hand pressed tile with a leaf imprint – about 4” x 11”. Sitting on the scrap walnut an ebayer sent me. The top is an oil painting of a Dogue De Bordeaux, 12” x 16” I still can’t get the hang of getting te pics to post at the bottom, sorry. -- - Cindy, texture freak - |
#7 posted 844 days ago |
If all you want to do is enhance the figure of the walnut I would not even mess with a stain or dye at all. Either choice is going to clound the natural grain pattern to some extent. I would sand to 320 or 400 grit, burnish the surface with 0000 steel wool and then apply a couple thin coats of boiled linseed oil to darken and bring out the figure of the walnut. Then you could seal with shellac or poly before painting. -- Aaron in TN -http://www.amwellsfurniture.com |
#8 posted 844 days ago |
I’m going to try that on the reverse side of that scrap piece in an above pic. I doubt I can paint on the poly, so I’ll try painting over the linseed oil after it’s nearly dry. After all, boiled linseed oil is a traditional painting medium for oils – it’s probably a natural fit. I’m thinking that if the linseed oil isn’t totally dry, it will help wick the oil pigments into the wood pores, without bleeding. When applying boiled linseed oil for a wood finish, do you flood, let it sit, and wipe off the excess? How many coats are typical, and what kind of drying time am I looking at? (we’re experiencing about 65% and up humidity lately. Actually it’s snowing today) Thanks! -- - Cindy, texture freak - |
#9 posted 844 days ago |
Any opinions on the differences, pros & cons, of tung oil, polyermized tung oil, and boiled linseed oil? -- - Cindy, texture freak - |
#10 posted 841 days ago |
Oil over oil is just fine. The main concern is letting the subfinish cure/dry fully before covering it with poly (in a nutshell). -- Jonathan, Denver, CO "Constructive criticism is welcome and valued as it gives me new perspectives and helps me to advance as a woodworker." |
| Forum | Topics |
Woodworking Skill Share
8785 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1523 |
3542 |
15757 |
Hand Tools
2031 |
Jigs & Fixtures
494 |
Wood & Lumber
2834 |
808 |
Focus on the Workspace
900 |
766 |
Woodworking Trade & Swap
2738 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6150 |
