Workbench material question
Forum topic by Kevin posted 493 days ago 1509 views 0 times favorited 8 replies Add to Favorites Watch
View Kevin's profile
Kevin
294 posts in 710 days
493 days ago
Topic tags/keywords: ash pine workbench knotty pine reclaimed recycled
As some of you have probably read, I recently found out the house I am tearing down has rough cut Ash studs in it. I am think I will use these for my workbench top.
(see my blog on the house process: http://lumberjocks.com/jocks/KevinHuber/blog/3649 )
There is also some 2” x 6” clear pine that was used for the door jambs. It seems really heavy for pine, but I am pretty sure that is what it is.
Do you think the pine would be better for the workbench base or do you think the Ash would be better?
I plan to use it for some hand tool work, but it will also get used for some portable power tool jobs as well. I want a vise on the front and the side. I haven’t fully decided on the design and am in the process of reading Chris’s Workbench book right now.
The pine will clean up at 2×6 and the Ash probably closer to 1 3/4×3 3/4.
-- Kevin, Wichita, Kansas
View GaryK's profile
GaryK
9430 posts in 740 days
493 days ago
Since ash is at least twice as hard as pine, I would use the ash for the top and pine for the base.
I used southern yellow pine for the base on my table and it works great.
View Peter O's profile
Peter O
982 posts in 626 days
493 days ago
I think the pine would be fine for the base. I’ve seen several very sturdy benches built on pine frames. Personally, I’d use the ash for the whole thing if I had enough ash available … but it would just be out of personal preference.
-- http://www.north40custom.com -- http://north40studios.etsy.com --
View jcees's profile
jcees
530 posts in 550 days
493 days ago
Either way you’ll have a fine bench using those two woods. My bench is ALL Southern Yellow Pine and was fabricated from 2x material. Mostly from 2”x12”x16’ so I could avoid knots and wany grain. The thing I like about the SYP for the top is that it’s not as slippery as a “hardwood” top. Again, either wood will suffice and comes down to what you can get from the amount of material you have or can attain.
Not mentioned but important, let that stuff acclimate for a season or two in your space before you build it. Keep us informed and put up some pics. We all love the benches.
always,
J.C.
-- "Imagination is more important than knowledge" -- Albert Einstein
View John's Woodshop's profile
John's Woodshop
110 posts in 768 days
493 days ago
I would echo what Gary said…...Ash for the top and pine for the base. Should work great.
Joihn
-- John -- Racine, WI -- Woodworking..."It's not just a Hobby, it's an Adventure"
View TampaTom's profile
TampaTom
63 posts in 505 days
493 days ago
Hey, if you have the ash for the top, go for it.
My workbench is an old front entry door… I got it for free and it works pretty well for me! :D
-- Tom's Workbench - http://tomsworkbench.com
Kevin
492 days ago
Thanks for the advice guys.
I think I will try out the pine on the stand after all. I figured it’d be OK, but it is always nice to have other thoughts on things.
Thank you.
View Dadoo's profile
Dadoo
1674 posts in 742 days
492 days ago
Mine’s all pine in the base and pressure treated where the wood meets the floor. I’ve had no problem with it and if it gets dinged…so what. Costs less too.
View Thos. Angle's profile
Thos. Angle
3949 posts in 714 days
492 days ago
My new bench (see my projects) has a pine base. Works very well.
-- Thos. Angle
Bookmark And Share This Page
