Sled Plans!
Forum topic by oleCB posted 01-26-2011 05:02 AM 1824 views 1 time favorited 6 replies Add to Favorites Watch
View oleCB's profile
oleCB
77 posts in 2584 days
01-26-2011 05:02 AM
Topic tags/keywords: sled jig question resource tablesaw
After looking at several table saw sleds here, one will be my next project. (After I finish the last 3 of my stands AND if I can stay out of here long enough!)
Any opinions on the best set up/plans for one? I had seen them before but didn’t understand what good they are until reading what you all had to say about them.
I’ve always relied on my skill saw skills and lots of sanding before.
Thanks in Advance,
ed
-- There was only one perfect carpenter... It wasn't me!
View scrappy's profile
scrappy
3506 posts in 3334 days
#1 posted 01-26-2011 07:44 AM
I made my sled for the miter cuts on my segmented turning. It is set at 22 1/2 deg for an 8 piece segment.
Have seen a lot of them with adjustable angles for multiple uses.
Mine is simply a board with 2 sliders under it for the miter slots. Attached the angle block where needed and away I go.
Scrappy
-- Scrap Wood's the best...the projects are smaller, and so is the mess!
oleCB
#2 posted 01-26-2011 07:54 AM
Scrappy,
Thanks! I think I found what I need @ http://www.eaglelakewoodworking.com/post/Super-Sled-Crosscut-and-Miter-Sled.aspx. Someone else had posted it here. My mind has been working overtime ever since I looked at the videos there. I am going to like you did, make at least one to speed up making my saddle stands. I WILL make one of their super sleds tho!!
Thanks Again,
ed
View b2rtch's profile
b2rtch
4847 posts in 2951 days
#3 posted 01-26-2011 01:57 PM
the supersled is sweet/
-- Bert
View docholladay's profile
docholladay
1287 posts in 2962 days
#4 posted 01-26-2011 02:40 PM
I wouldn’t over complicate it. The purpose of a table saw sled is simply to provide a safe way to hold your workpiece so that you can slide it across the saw table safely. The critical part is that it will hold the size workpieces that you typically would use and that it will hold the workpiece to cut at the appropriate angle. If you are wanting to square off your boards, the fence needs to be dead square. If you want to cut miters, then, depending on the actual miter angle, that needs to be dead on. Other than that, it is just another jig. They don’t have to look good, just get the job done safely and acurately.
BTW, you mention using a circular saw. I have made jigs to guide a circular saw that work very well to get some very acurate cuts. A circular saw with a good sharp blade appropriate to the material and an acurate jig can make very precise and clean cuts.
Doc
Doc
-- Hey, woodworking ain't brain surgery. Just do something and keep trying till you get it. Doc
View jcwalleye's profile
jcwalleye
306 posts in 2976 days
#5 posted 01-27-2011 07:35 AM
Take a look at this sled: http://woodworkstuff.net/CCSMark.html. Its a bit complicated to build, but the removable inserts allow you to use it with a dado blade stack and you can make zero clearance inserts easily. I have one made from 3/4 particle board and that’s way too heavy. I may rebuild it someday.
-- Trees, a wonderful gift --Joe--
View rogerw's profile
rogerw
262 posts in 2593 days
#6 posted 01-28-2011 01:18 AM
this one is pretty sweet. http://www.woodsmithshop.com/download/403/precisioncrosscutsled.pdf
you have to be a member of their site to gt it but it is free and it only takes an email address to join, plus you get weekly tip that i have found useful at times.
have fun
-- >> my shop teacher used to say "do the best at everything you make for your mom because you're going to see it for the rest of your life!" <<
