DWS780 Sliding Compound Miter Saw Miter..finally
Forum topic by sreilly24590 posted 09-14-2017 07:44 PM 3030 views 0 times favorited 8 replies Add to Favorites Watch
View sreilly24590's profile
sreilly24590
130 posts in 549 days
09-14-2017 07:44 PM
So I got a great deal from a local building supply company in my area and now I’m looking to see what the best blade I should get for my use. It will be used for cross cutting hardwoods and plywood as expected in my shop. It will see little if any construction work unless I finish off some of the basement but no plans there.
I plan to build a miter saw station to assist in long board support and storage. From classes I’ve taken at a local woodworking store I noticed they use a Freud Diablo LU91M012 72 tooth thin kerf blade. I know they make 80 and 96 tooth blades as well but wonder what the best guide is in deciding on the best blade to get. I know the number of teeth makes a big difference but there has to be more to it than that. Suggestions on the topic or best places to find sound advice?
Thanks,
Steve
-- Steve, Virginia
8 replies so far
View Ripper70's profile
Ripper70
1113 posts in 1025 days
#1 posted 09-14-2017 08:15 PM
I have the same blade on my 12” slider and it works beautifully. Whichever blade you decide to purchase, having the -5 degree hook will increase the safety factor when using the saw a bit and, I think, makes for smoother operation.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
View ChipSawdust's profile
ChipSawdust
18 posts in 372 days
#2 posted 09-14-2017 08:31 PM
I had one of those saws new and the supplied blade was pretty good as I recall. But Freud makes better blades in most cases than DeWalt does.
View Rich's profile
Rich
3527 posts in 706 days
#3 posted 09-14-2017 08:33 PM
When I think crosscut, I think 80 tooth for 10” blades and 96 for 12”. I have an 80 tooth on my 10” Makita and it cuts well. I doubt if a few less teeth would make a huge difference though.
View BillyDoubleU's profile
BillyDoubleU
152 posts in 558 days
#4 posted 09-16-2017 03:34 AM
Have a diablo 80t fine finish on mine and it melts away wood.
http://www.homedepot.com/p/Diablo-12-in-x-80-Tooth-Finishing-Saw-Blade-D1280X/100036926
-- "But I’ve bought a big bat. I’m all ready you see. Now my troubles are going to have troubles with me!” ~ Dr. Seuss
sreilly24590
#5 posted 09-16-2017 12:27 PM
Thanks for the replies. You hate to buy blades that only do a barely decent job. Of course using the saw properly makes a big difference. I’ve seen people speed through the cut and pull through it rather than push. I’ve seen where people will score their cut first with a very light pass and then cut especially on plywood.
So it looks like a good choice for this saw. It would mostly be used on hardwoods but will it cut plywood with little tearout? I see they also make a cabinetmakers blade with 72 teeth with a going price of about $110. Ant thoughts experience with this blade?
Steve
-- Steve, Virginia
View waho6o9's profile
waho6o9
8356 posts in 2694 days
#6 posted 09-16-2017 03:08 PM
sreilly24590
#7 posted 09-16-2017 04:52 PM
http://lumberjocks.com/knotscott/blog/12395
HTH
- waho6o9
Thanks for that indeed. Well written and clear. I should have read this before methinks. I’ve saved this both in Favorites as well as locally on my hard drive as a pdf for off-line reading.
Thanks Again,
Steve
-- Steve, Virginia
View edh1's profile
edh1
8 posts in 3515 days
#8 posted 09-17-2017 07:08 AM
Congrats on the saw purchase. I got mine a year ago,,happy happy.
