Dealing with flooded equipment
Forum topic by TheWoodNerd posted 09-14-2017 04:04 PM 1057 views 0 times favorited 19 replies Add to Favorites Watch
View TheWoodNerd's profile
TheWoodNerd
291 posts in 3425 days
09-14-2017 04:04 PM
Hurricane Irma left my shop with about two feet of water in it. Luckily, most stuff that could be damaged was stored higher than that.
However, the motors for my planer, jointer, bandsaw, etc, spent about 24 hours submerged in water.
Has anyone dealt with this before and care to share any tips on what needs to be done before applying power?
-- The Wood Nerd -- http://www.thewoodnerd.com
19 replies so far
View Nubsnstubs's profile
Nubsnstubs
1433 posts in 1964 days
#1 posted 09-14-2017 04:21 PM
I would think if your motors were “Drip Proof”, open them to replace the bearings and then let them dry out before reassembly. It might be the solution for all the motors. I wouldn’t even think about starting them until they are dry…... Jerry (in Tucson)
View Tideline77's profile
Tideline77
102 posts in 1005 days
#2 posted 09-14-2017 04:25 PM
sorry your having to deal with this, what a bummer
is it covered on your homeowners insurance ?
was it salt water ?
View jawqn87's profile
jawqn87
26 posts in 2833 days
#3 posted 09-14-2017 04:26 PM
Let them dry out for a long time. We are recovering from Hurricane HArvey and I have many friends who’s air conditioner was submerged for 2-10 days. They were dried out completely and than they were running again. Important to note that in both cases, insurance totaled the air conditioner and they will be buying new. Might see if your insurance can help in these cases.
TheWoodNerd
#4 posted 09-14-2017 04:27 PM
Homeowners doesn’t cover flooding, at least not in this part of the country. We do have National Flood Insurance, but that can take a really long time. If I can get my stuff up and running again, that would be vastly preferable.
View Loren's profile
10477 posts in 3881 days
#5 posted 09-14-2017 04:29 PM
You’ll need to remove dirt from the floodwater.
This can be done fly flushing components
with clean water if the flood was a freshwater
flood. If you don’t want to do that, disassemble
as much as you can and thoroughly clean with
brushes, compressed air, mineral spirits to
get the grime off. Then you’ll have to dry
everything thoroughly.
View TheFridge's profile
TheFridge
10814 posts in 1720 days
#6 posted 09-14-2017 05:08 PM
I’ve had to deal with a bunch of flooded stuff.
Pull the motors and open them up to dry. I’ve opened up motors a year after they’ve flooded and some still had water in it.
Replace all flooded bearings. All it takes is a little of that fine grit in the grease to kill it.
Starters need to be disassembled and sprayed with contact cleaner.
You can spray motors and whatnot with a hose, just make sure they dry thoroughly before reassembly.
View papadan's profile
papadan
3584 posts in 3602 days
#7 posted 09-14-2017 06:23 PM
Loren and Fridge have the right ideas. Disassemble, clean, dry, lubricate, reassemble.
TheFridge
#8 posted 09-14-2017 06:49 PM
My buddy got 3’ in his shop last august. He wanted to take the wait and see approach.
Every single bearing that got water was replaced eventually. We went to use his lathe last month. A full year after. Bearings locked up.
3/4 of the starters on his equipment had to be pulled apart and cleaned and/or repaired.
View Carloz's profile
Carloz
1147 posts in 825 days
#9 posted 09-14-2017 07:08 PM
How old is your equipment? The insulation pads between windings and between winding and the core nowdays is plastic that withstand water well. Older meterials were asbestos paper or paper soaked with resins that will be permanently damaged by water, also water likely brought all kind of deposits between the coils and it is impossible clean it completely. Those deposits will damage the wire insulation once the vibration starts. So file your federal insurance claim even if you manage to start thr equipment.
5229 posts in 2727 days
#10 posted 09-14-2017 07:29 PM
Homeowners doesn t cover flooding, at least not in this part of the country. We do have National Flood Insurance, but that can take a really long time. If I can get my stuff up and running again, that would be vastly preferable.
- TheWoodNerd
I congratulate you on that, the news is reporting that 80% of the folks din’t have that coverage. Even so, will it be 100% replacement? BTW, the disassemble, clean, dry and lube (and reassemble) is the approach I’d take. I sshould add, while I have taken wet motors apart, I’ve never been flooded…so I’m not speaking from actual experience.
View scrubs's profile
scrubs
46 posts in 494 days
#11 posted 09-14-2017 08:51 PM
As others have said, disassemble, clean, lube. Replace your bearings now.
I’m a New Orleans native and have had my fair share of flooded shops! I’ve been lucky enough to only lose one motor to flood, the rest were salvageable thru cleaning, new bearings etc. To be fair the one that I couldn’t get to run right was really old and never was great to begin with, so I just replaced it.
I highly suggest just buying new bearings now, don’t try and save the ones that are in there. Not worth the hassle really.
-- It all seems like a good idea at some point...
View GR8HUNTER's profile
GR8HUNTER
5361 posts in 946 days
#12 posted 09-14-2017 10:51 PM
maybe an electric motor service place could rebuild them for you :<))
View AlaskaGuy's profile (online now)
AlaskaGuy
4978 posts in 2543 days
#13 posted 09-15-2017 02:37 AM
- GR8HUNTER
Probably can find one that not swamped with work.
View bbasiaga's profile
bbasiaga
1242 posts in 2229 days
#14 posted 09-15-2017 03:01 PM
- GR8HUNTER
- AlaskaGuy
Swamped with work….I see what you did there!
View builtinbkyn's profile
builtinbkyn
2677 posts in 1174 days
#15 posted 09-15-2017 03:07 PM
Not sure it will work in this instance, but there are cleaners for electronic equipment that come in an aerosol. It’s still a lot of work as you would need to disassemble the motors and switches, but it should remove grim, grit and oxidation that accumulated. Sorry you’re having to deal with this.
-- Bill, Yo!......in Brooklyn & Steel City :)
