Miter sled on a router table?
Forum topic by JoeRodricks posted 01-26-2011 09:07 AM 2375 views 0 times favorited 6 replies Add to Favorites Watch
View JoeRodricks's profile
JoeRodricks
3 posts in 2588 days
01-26-2011 09:07 AM
Topic tags/keywords: router table miter miter sled question
I’m working on picture frames so I’m only talking about small stock (no bigger than 1×3s) and 45s.
I have a hand-me-down Makita miter saw with a new blade in it. I can set it to a 45 with a good square and get pretty good results- but I’m looking to make easy, repeatable 45s.
I have a router table which I’ve been learning (it’s only a month old). My thought is this, since I don’t have a table saw:
Could I build a miter sled and slide it down the miter groove(like you would on a table saw) using a straight router bit to cut?
I’m thinking tat if I put the effort into making the sled properly I should be able to get repeatable results.
My other option is to buy a junky table saw for this purpose. Any thoughts on this would be greatly appreciated.
View dorran's profile
dorran
140 posts in 3143 days
#1 posted 01-27-2011 07:56 AM
I would say use a miter saw or a miter box. Routers aren’t too great for cutting lines.
-- Life is about choices. You can spend a lot of money on furniture and have really nice furniture; Or you can spend a lot on tools and have even more expensive, crappy furniture. I made my choice.
View Gene Howe's profile
Gene Howe
10138 posts in 3338 days
#2 posted 01-27-2011 03:27 PM
Depending on the width of your frame stock, there are router bits that will yield a 45. Chamfer bits
You could use your suggested method for the final cut. I wouldn’t attempt to cut the full width stock with a router bit.
A well tuned table saw is a better choice, IMHO.
16272 posts in 4128 days
#3 posted 01-27-2011 03:42 PM
In theory, sure you could do it. But I think you’d have problems with tearout, and with cutting precisely to the line, as dorran pointed out.
JoeRodricks
#4 posted 01-27-2011 03:45 PM
Is it possible to square up a $200 table saw blade and make a precise enough sled to get perfect miters? I really would hate to buy a tool that’s setup for failure.
View Richard's profile
Richard
1916 posts in 2600 days
#5 posted 01-28-2011 10:50 PM
I would think the miter saw should be just about perfect for this. If the one you have is really out of whack you might think of getting a newer one rather than spring for a table saw, unless you have enough other use for it as well as the space.
JoeRodricks
#6 posted 01-28-2011 11:54 PM
Here’s my new thought:
There are 2 things that control how accurate my miter saw cuts are.
a) the angle of the blade relative to the fence
b) the straightness of the edge of the board on the fence
I just (today) took delivery of a nice miter square. It’s heavy stainless steel with a 45° edge that promises to be accurate to 0.2mm per 100mm. It’s nice and heavy with sharp edges. One can’t help bit feel precise when holding it. I’m going to use it to take care of a)... the fence/blade angle.
In order to take care of b)... the presumably not straight board edge, I’m going to run it through the router table with the fence off-set 1/32” like a joiner. My fence has that function built in so it should yield accurate and repeatable results.
I think then I can keep the trued edge along the fence and everything should fit perfect. If they don’t, I’ll work on my sawdust & super glue filling technique.
