| Forum topic by Woodshopfreak | posted 641 days ago | 303 views | 2 times favorited | 8 replies | ![]() |
641 days ago |
641 days ago |
Tyler,
Here are 3 web sites that I found helpful:
http://home.nj.rr.com/afoust/dovetails.html#saws
http://www.amgron.clara.net/index.htm
http://www.handcutdovetails.com/ |
641 days ago |
Tyler, some months back I posted a blog entry that contains a 37 minute video on how to cut dovetails by hand: You might want to take a look. Alin -- -- Alin Dobra, Gainesville, Florida |
641 days ago |
Hi Tyler, I’d also recommend Alin’s videos. They’re very thorough and will give you a good idea of how to proceed. And if you post pictures and comments of your attempts, you will probably get good feedback from the community. -- Eric at http://adventuresinwoodworking.com |
641 days ago |
I concur. Alin’s video set me on my way to hand-cut dovetails. -- The significant problems we face cannot be solved by the same level of thinking that created them |
641 days ago |
you can use a router to remove most of the material for the pins and then clean them up with a chisel. then just cut the tails with a hand saw and remove it with a chisel. it takes some time to learn though. i will probably have something on dovetails in one of my upcoming podcasts. |
641 days ago |
I have several of Rob Cosman's DVDs and really enjoy them. They are full of good information. Rob is also going to release a Shop Manual that you can take to the shop with you. If you do a little research, you quickly find that there are many techniques to cutting dovetails. You may need to try a couple, to find the one that works for you. Experiment and have fun with it. It will be frustrating at first, but hang in there. Cutting dovetails is a skill anyone can learn, but it does take a lot of practice. |
641 days ago |
I would enthusiastically second watching Alin’s video. He really does an excellent job. |
639 days ago |
teenagewoodworker, I would agree with you but I think using a coping saw is much faster and easier to control. A router without a guide on the edge and not going through the marking lines takes acrobatic abilities, not to mention that it is noisy and makes a lot of dust. If you opt for a router with a guide you might as well go with a dovetailing jig. Coping saws (Lowes and HD sell them for less than 10$) are very aggressive and relatively easy to use. The only problem is the rough cut but you are cleaning up with a chisel anyway. Alin -- -- Alin Dobra, Gainesville, Florida |
| Forum | Topics |
Woodworking Skill Share
2934 |
3964 |
258 |
956 |
226 |
Woodworking Trade & Swap
622 |
Coffee Lounge
2402 |
LumberJocks.com Site Feedback
525 |
