Issue with Porter Cable Dovetail Jig 4212
Forum topic by Gregg M. posted 09-14-2017 12:54 PM 1126 views 0 times favorited 9 replies Add to Favorites Watch
View Gregg M.'s profile
Gregg M.
210 posts in 1919 days
09-14-2017 12:54 PM
Topic tags/keywords: half blind dovetail jig porter cable baltic birch plywood drawers
I recently bought the PC Dovetail Jig 4212 to make half blind dovetails in 1/2” (actual 12mm) Baltic birch drawers. I had used another PC jig prior to getting this one. They are very similar. I am using the 3/4 bushing and hte dovetail bit provided. I spent time time adjusting the jig to get a good fitting joint. While the joint fits good and looks good, there are visible gaps on the inside of the drawer (see pictures). I don’t believe there is anyway to fix this. Has anyone else had a similar problem routing half blinds in 12mm baltic birch?
Gaps visible from inside drawer
Good fitting joint on outside of drawer
-- Marvel Woodworking, West Chester, PA - http://www.MarvelWoodworking.com
9 replies so far
View bbasiaga's profile
bbasiaga
1242 posts in 2232 days
#1 posted 09-14-2017 01:12 PM
Your guide plate is too far back, allowing you to push the router too far back and make that slot too deep. Try sliding it forward a bit.
I have the PC jig. All of these seem to be a bit finicky but once set up are very repeatable.
Brian
View Bill White's profile
Bill White
5148 posts in 4197 days
#2 posted 09-14-2017 01:35 PM
I have the 4210, and I agree that the plate needs adjusting a bit.
Fiddly for sure at first, but once set up, it works well.
Bill
-- bill@magraphics.us
Gregg M.
#3 posted 09-14-2017 01:48 PM
Thanks Brian…I have tried moving the template forward to reduce the depth of cut on the pins. That just ends up making the tail sit proud of the pin sockets. Looks like there is another issue.
View Jim Jakosh's profile
Jim Jakosh
21956 posts in 3342 days
#4 posted 09-14-2017 02:21 PM
We just had a demo on that jig at our guild with 1/2” stock and there were no gaps. It must be an adjustment.
The guy that put on the demo teaches it at woodcraft.
His name is Dale Smith. Give him a call at 616 560 1219
Jim
View GR8HUNTER's profile
GR8HUNTER
5377 posts in 949 days
#5 posted 09-14-2017 02:34 PM
IMO ….I think it is your wood thickness …cuz 12mm is not quite 1/2 inch as that jig is designed for
Gregg M.
#6 posted 09-14-2017 02:42 PM
- GR8HUNTER
I think you are correct Tony. The BB ply that I picked up was suppose to be 1/2”. What they sold me was 12mm BB ply instead.
bbasiaga
#7 posted 09-14-2017 06:08 PM
Perhaps you could solve that by finding a metric equivalent dovetail but that was slightly smaller in diameter.
Brian
View bandit571's profile
bandit571
21986 posts in 2920 days
#8 posted 09-14-2017 06:14 PM
Move the guide forward…..to ease the tails into the sockets, use a chisel to “square” the rounded cuts off. BTDT
This was also the last time I ever used that jig…
Gregg M.
#9 posted 09-14-2017 07:57 PM
I will give that a try. A lot more work than I had anticipated. Next time I will use thicker drawer stock.
