Slot cutter question
Forum topic by depictureboy posted 01-25-2011 02:36 PM 904 views 0 times favorited 0 replies Add to Favorites Watch
View depictureboy's profile
depictureboy
420 posts in 3545 days
01-25-2011 02:36 PM
Big Blue had their 1/2” arbor slot cutting arbors on clearance for 6 bucks, so i picked one up…My question is, can I use a 1/4” slot cutting blade to make the grooves in in a stub tenon & Groove door frame? Would it basically be the same idea as if I were using a dado blade – groove flip end for end and grove again to make sure its centered?
should I use an 1/8th inch instead of the 1/4 to give myself some leeway? This could speed up my door/drawer production if so…thanks..
-- If you can't build it, code it. If you can't code it, build it. But always ALWAYS take a picture.
0 replies so far
