Cast Iron Leg Workbench Racking
« back to Joinery forum
Forum topic by Hoehn posted 09-13-2017 07:10 PM 636 views 0 times favorited 2 replies Add to Favorites Watch
View Hoehn's profile
Hoehn
1 post in 491 days
09-13-2017 07:10 PM
I recently started building a new workbench utilizing some old cast iron legs I refinished. Bench top is 6’ x 32” x 4” thick laminated maple and legs are through bolted. There is a shelf below to keep the legs square. I knew I was going to have a problem with racking because of the lack of aprons, original plan was to add them, but now I really don’t want to drill into the vintage legs. Right now it only racks about a 1/2” but because of the weight of the top it will continue to “bounce” back and forth for a very long time.
Do you think installing cable and turnbuckles from bottom of one leg to opposite top on both sides will stiffen it up enough? In theory it should, but I’ve only ever seen solid threaded rod turnbuckles used in this case and not cable. Any help would be great.
2 replies so far
View ArtMann's profile
ArtMann
1215 posts in 1052 days
#1 posted 09-13-2017 11:27 PM
Without any photos of the table or the repair hardware, it is going to be hard to make a judgement call. I will say that the racking will get worse over time if you don’t do something about it.
View Loren's profile
10477 posts in 3884 days
#2 posted 09-13-2017 11:35 PM
Cables will probably work, but I know for
sure that stretchers will work. A shelf
won’t stop racking because it is oriented
in the wrong axis.
