Small compressor.
Forum topic by richardchaos posted 09-13-2017 04:26 PM 290 views 0 times favorited 2 replies Add to Favorites Watch
View richardchaos's profile
richardchaos
583 posts in 249 days
09-13-2017 04:26 PM
I have a air compressor large enough to do Pneumatic gigs such as nailing and stuff BUT way to small to do any kind of spray finishing. Takes longer to pressure back up than it sprays.
I read something about a PRESSURE TANK application. AS i under stand it it is stank where you put your Finishing material in my case Water Poly. Then it forces the material to the gun. So you have 100% of stuff coming out.. Sort of like a Airless paint sprayer. Don’t want to buy a big arse high capacity compressor
Is that the way it works
Any experience using this one here?
Rixh
-- β€œIn a time of universal deceit, telling the truth is a revolutionary act.” ― George Orwell
2 replies so far
View papadan's profile
papadan
3584 posts in 3238 days
#1 posted 09-13-2017 04:38 PM
Not sure about the tank to put your finish in, but you can add a tank to your compressor so it will hold more air volume and allow you to spray.
View MrRon's profile
MrRon
4560 posts in 3113 days
#2 posted 09-13-2017 07:31 PM
You can use a paint pressure pot or an air storage tank, BUT either will cause the small compressor to run continuously in order to maintain pressure, which it probably won’t. The pressure will be correct at the start, but as soon as the pressure drops, the compressor will switch on, but because it is small, it will not keep up with the required pressure. The CFM output of the compressor at the spraying pressure must match or exceed the CFM requirement of the spray gun.
