Questions on finishing pine
Forum topic by Hermit posted 09-13-2017 02:31 AM 482 views 0 times favorited 9 replies Add to Favorites Watch
View Hermit's profile
Hermit
144 posts in 1194 days
09-13-2017 02:31 AM
So I’ve been working on face frames for my shop cabinets made of pine.
Sanded with 80 grit, 120, 150 then 220. Felt smooth when done.
Applied wood conditioner, waited 5 mins per instructions, wiped off excess which wasn’t much as it all soaked in.
Waited 15 mins per instructions, grain was raised as I expected. Sanded with 220 lightly until smooth again.
Applied danish oil. Waited 30 mins. Added more, waited 15 mins, all per instructions. Grain raised again.
After 72 hours, light sand with 400. Applied 5 coats lacquer. Grain raised again. 400 sand one more time extremely light, then one last coat of lacquer,
So after all that it’s still not as smooth as I had hoped for.
Is it normal with pine for the grain to keep raising or am I doing something wrong?
-- I'm like the farmer's duck. If it don't rain, I'll walk.
9 replies so far
View Rick_M's profile
Rick_M
10800 posts in 2249 days
#1 posted 09-13-2017 02:43 AM
Oil and oil based products don’t raise the grain. Water, alcohol, shellac, and lacquer will raise the grain. Be more specific about the products used and that might help. But I don’t know why you would use lacquer over Danish Oil. I like to keep it simple, pick one finish and stick with it.
-- http://thewoodknack.blogspot.com/
116804 posts in 3446 days
#2 posted 09-13-2017 02:47 AM
View Lazyman's profile
Lazyman
1556 posts in 1256 days
#3 posted 09-13-2017 02:54 AM
Are you sure you aren’t just getting dust in your finish? Once you applied the Danish oil, I would not expect any raised grain because it should pretty much lock down the grain.
woodbutcherbynight
3729 posts in 2278 days
#4 posted 09-13-2017 03:06 AM
https://www.youtube.com/watch?v=E-fe8-y9HpA
- a1Jim
Interesting video, thanks for posting Jim
Hermit
#5 posted 09-13-2017 01:22 PM
Thanks for the link Jim. Glad it’s not just me. I think I’ve watched just about every video on staining pine except Charles Neils videos. What he said makes since now.
Lazyman, I think you nailed it.after staining more last night there was some fine dust on the surface.
View gargey's profile
gargey
869 posts in 644 days
#6 posted 09-13-2017 01:37 PM
I believe the OP is calling any kind of bumps or texture “raised grain.”
View richardchaos's profile
richardchaos
583 posts in 248 days
#7 posted 09-13-2017 01:43 PM
Here is my favorite PINE Finish…
Prep as called for. 2-3 maybe four flood coats of (Natural) Danish Oil. Then 2-3 coats Semi gloss water based poly. SAND. 2-3 coats poly. SAND 2 more coats poly. WAX!
Or forget the poly and put on several coats of Finishing wax!
-- “In a time of universal deceit, telling the truth is a revolutionary act.” ― George Orwell
richardchaos
#8 posted 09-13-2017 02:07 PM
Shake up your danish oil can ALSO you may wish to Strain the contents before you use it. Danish oils has a nasty habit of drying on the top of theca then cracking and getting back into the can.
View newwoodbutcher's profile
newwoodbutcher
720 posts in 2719 days
#9 posted 09-13-2017 09:05 PM
This Ponderosa pine table was finished with Gel stain (Walnut I think) and wipe on Poly.
-- Ken
