Carter stabilizer questions.........
Forum topic by carolinagene posted 09-13-2017 12:41 AM 476 views 0 times favorited 3 replies Add to Favorites Watch
View carolinagene's profile
carolinagene
6 posts in 651 days
09-13-2017 12:41 AM
if using a 3/16” blade with the stabilizer, any problem cutting hardwoods up to 6” thick ? Is it ok to leave the stabilizer on the saw all the time, or will prolonged use quickly wear out the bearing on it?
3 replies so far
View Andybb's profile
Andybb
1599 posts in 838 days
#1 posted 09-13-2017 12:49 AM
Do you mean to resaw a 6” tall board or just cutting through a 6” block of wood like used in making a bandsaw box??
Assuming you mean a block of wood….just use a sharp blade and take it slow. The stabilizer is meant as a replacement for the stock guides for 1/4” or smaller blades.
But Brad is the bandsaw man. Brad?
-- Andy - Seattle USA
carolinagene
6 posts in 651 days
#2 posted 09-13-2017 12:58 AM
Andy…...a block of wood…..
View Redoak49's profile
Redoak49
3731 posts in 2223 days
#3 posted 09-13-2017 01:14 AM
I do not think the stabilizer was designed for such a cut. I would put the standard guides back on. I have the Carter Stabilizer on a 10” bandsaw so I do have experience with them.
