Homemade Vacuum Press
Forum topic by Bohaiboy posted 09-12-2017 05:18 PM 514 views 0 times favorited 9 replies Add to Favorites Watch
View Bohaiboy's profile
Bohaiboy
76 posts in 1792 days
09-12-2017 05:18 PM
Toying with the idea to make a homemade vacuum press. Anyone on here done it? Approximate cost? I have been to joewoodworker and veneersupplies.com, but I would have to assume I have all the correct parts. Also, how many have made their own bag?
Thanks all.
-- Tim, Houston, TX area
9 replies so far
Bohaiboy
#1 posted 09-12-2017 05:28 PM
Never mind on the kit, I found something on joewoodworker. I would like to know from those out there if you went with the pump system or the venturi using your air compressor?
View Loren's profile
10390 posts in 3646 days
#2 posted 09-12-2017 06:35 PM
I bought a Gast pump on ebay for less than
$100. I made my own bag from supplies
I bought from Joe. At the time I don’t think
he sold finished bags.
4985 posts in 2491 days
#3 posted 09-12-2017 07:38 PM
I bought everything from Joe. My system is built on one of the Rebuilt Thomas Ritchie pumps (I think there has been a name change for these since then) he sells, and the other stuff in the kit. It’s awesome, as well as a lot of fun to build. I also got my bags from him. The first one was vinyl, then I bought a polyurethane one when he had them on sale….get one of those. They are so superior to the vinyl it becomes well worth the extra cost.
View madts's profile
madts
1862 posts in 2337 days
#4 posted 09-12-2017 07:56 PM
Try Gougeon Brothers INC. They do epoxy and bagging very well.
—Madts.
-- Thor and Odin are still the greatest of Gods.
View HorizontalMike's profile
HorizontalMike
7757 posts in 2912 days
#5 posted 09-12-2017 08:26 PM
I had a Gast vacuum pump, made my own bag with thick flexible plastic sheet material, and I used an old refrigerant tank (think Freon). Since I did not have an automatic sensor, that extra volume I got from the refrigerant tank came in VERY handy in maintaining the vacuum over time. At the time, I was vacuum bagging fiberglass/Carbon Fiber/Spectra/Kevlar/others over hot wire cut Styrofoam aircraft airfoils for my radio controlled sailplanes. Had great fun on a shoe-string budget when younger in the 80s and 90s… Sold it all in the end.
Now-a-days, if I were to do this again, I would opt for an automatic vacuum sensor system that takes the tediousness out of the process. After all, that West Systems Epoxy and all that high-tech cloth costs way too much for each “failure”, if you get my drift… ;-)
In other words, too much/many expensive parts in the process to risk effing-up. Just my 2-cents worth. Good luck in your choices…
View jtdon's profile
jtdon
15 posts in 504 days
#6 posted 09-12-2017 08:29 PM
Here’s an article about making a bag from shower pan lining.
http://www.woodmagazine.com/woodworking-tips/editorial-extras/shop-made-vacuum-press-bag
View splintergroup's profile
splintergroup
2011 posts in 1220 days
#7 posted 09-12-2017 08:51 PM
I have the venturi kit from Joe. I have an ample compressor so I went the venturi route, no other particular reason.
Cost-wise I believe you can same a little money by getting a vacuum pump.
View DS's profile
DS
2917 posts in 2418 days
#8 posted 09-12-2017 08:59 PM
I have built the version from Joe. It is a decent pump. The high efficiency venturi works well.
If I were doing this all day, everyday, it would be worthwhile to buy a commercial pump.
For the occasional projects I do that need a bag press, it is more than adequate.
I make my own bags using the same vinyl material (only thinner) that can be bought at fabric stores for relatively cheap, (Same stuff that Gramma used to cover her sofas – you might not remember that). I tried the glue Joe recommends to close his bags – I didn’t have much success (Lots of leaks), but, I found that double-sided tape works great!
HorizontalMike
#9 posted 09-13-2017 03:13 PM
Rope caulking from your local contractors store works fine with the vinyl sheeting.
