MDF strength and tips for a first time user.
Forum topic by crowlader posted 09-12-2017 02:04 PM 809 views 0 times favorited 26 replies Add to Favorites Watch
View crowlader's profile
crowlader
21 posts in 551 days
09-12-2017 02:04 PM
Topic tags/keywords: mdf strength tips first time first time question trick
I am about to start putting selling pieces in a booth at an artist market. I have an 8×8 space that I can make my own. essentially they like you to make a room or display case out of your space so my wife wants to make it look like a living room with trim and fake wood paneling on the lower half of the wall. Right now there is just some odd cardboard sheeting with 2×4 or 4×4 every four feet (essentially one on each corner and one in the middle of the wall). I am going to take down the cardboard and put up MDF Panels (I’m thinking 1/2in). It will let me wife paint it the color that she wants and I will be able to easily attach any trim to it that I need so that it looks like a living room. The issue I may have is that I will eventually need to put some shelves in the booth and I am not sure if MDF is going to be strong enough to hold the shelves. I cant imagine having anymore than 40-50 pounds on an approximately 6 foot shelf, but is there anything I should take into consideration when mounting the shelves? My first idea is that I should only drill into the studs, but there is only one in the middle of the wall. Should I consider putting some ply behind the MDF or will the MDF be strong enough to hold a few shelves.
The post may have been hard to follow, I typed it purely by stream of thought and edited the best I could. Any help would be appreciated!
-- Conner, Georgia
26 replies so far
View Elwyn24601's profile
Elwyn24601
15 posts in 653 days
#1 posted 09-12-2017 02:18 PM
my suggestion is to treat the MDF as drywall and use a toggle bolt (generally used for wallboard) with a diameter of 1/2 inch. in a 3/4 inch piece of wallboard that can support (roughly) 105 lbs directed away from the wall and 100 lbs directed down the wall. I’ll give a link to where I got these numbers so you can take a look. the chart for toggle bolts and their associated strength is approximately 2/3 the way down the page.
https://www.naturalhandyman.com/iip/inffastener/infanchor/infanchor.html
- John
crowlader
#2 posted 09-12-2017 02:24 PM
my suggestion is to treat the MDF as drywall and use a toggle bolt (generally used for wallboard) with a diameter of 1/2 inch. in a 3/4 inch piece of wallboard that can support (roughly) 105 lbs directed away from the wall and 100 lbs directed down the wall. I ll give a link to where I got these numbers so you can take a look. the chart for toggle bolts and their associated strength is approximately 2/3 the way down the page.
- John
- Elwyn24601
Thanks for the quick response and the article john. That sounds like a solid course of action.
-- Conner, Georgia
View Rich's profile
Rich
4002 posts in 827 days
#3 posted 09-12-2017 03:41 PM
Screws driven into the face of MDF hold extremely well. Anything driven into the edge won’t hold though.
View MrRon's profile
MrRon
5264 posts in 3481 days
#4 posted 09-12-2017 04:52 PM
Screws driven into the face of MDF hold extremely well. Anything driven into the edge won t hold though.
- RichTaylor
I would suggest using sheet metal screws which have a coarser thread than wood screws.
MrRon
#5 posted 09-12-2017 04:55 PM
I would use shelf brackets and secure them to the MDF wall with nuts, washers and screws unless you are over a stud. Then use wood screws to secure the brackets to the studs.
crowlader
#6 posted 09-12-2017 05:03 PM
- RichTaylor
- MrRon
Thanks for the input. I have heard different things about MDF when it comes to how well it holds screws.
-- Conner, Georgia
View eflanders's profile
eflanders
320 posts in 2088 days
#7 posted 09-13-2017 12:21 AM
You do know that MDF (unless treated) will soak in tons of moisture right? Are the shows you are doing indoors or outdoors?
View Loren's profile
10477 posts in 3886 days
#8 posted 09-13-2017 12:28 AM
You can buy screws designed for particleboard
and MDF. I think that like confirmat screws
they have big threads spaced widely. Screw
holes should be pilot drilled in MDF.
View Desert_Woodworker's profile
Desert_Woodworker
1673 posts in 1452 days
#9 posted 09-13-2017 01:46 AM
- eflanders
and if moisture is a concern – Medite MDF is the way to go.
-- Desert_Woodworker
Desert_Woodworker
#10 posted 09-13-2017 01:51 AM
- John
- Elwyn24601
+1
This is the answer that I would suggest- but there will be many more….
View AlaskaGuy's profile
AlaskaGuy
4991 posts in 2547 days
#11 posted 09-13-2017 01:59 AM
This is from personal experiences (for those who care) confirmat screws will hold in the edge of MDF
I have built a few things with MDF and confirmat screws and the didn’t have any issues. Here’s one of them.
AlaskaGuy
#12 posted 09-13-2017 02:21 AM
Perhaps I’ll get my wrist slapped for posting something out of my hands on experience but maybe Slat Wall might be of some use to you. I don’t know the ratings on it but they hang stuff on it all the time in store. Don’t get upset folks it just an idea to check into.
Desert_Woodworker
#13 posted 09-13-2017 02:23 AM
AK “I care” and I wish to add-
The fastener that I use with success “Type 17 w/nib” Pre drill 1/8” with a countersink. Caution: If you use a big box product it is not the same as a professional grade MDF and particle board.
p.s. AK why would you paint your project in Alaska, white? Just askin” and it is very nice. Or as the kids say “Bomb!”
View bondogaposis's profile
bondogaposis
5151 posts in 2589 days
#14 posted 09-13-2017 02:47 AM
40 -50 lbs on a 6 foot, 1/2” MDF shelf will sag like the dickens. One thing to consider is weight. MDF is heavy stuff. Is this something that you are ever going move once it is place?
-- Bondo Gaposis
AlaskaGuy
#15 posted 09-13-2017 02:49 AM
- Desert_Woodworker
I didn’t paint it white, the customer did
I have used those screws before, I still like the confirmat screws for the edge of MDF.
I do like those screws for plywood boxes
If you suggesting I don’t know the difference for the big box stores quality and and the material I get form an honest to goodness cabinet supply place I deal with I might have to block you for the insult. Something I’ve never done before.
https://hsiak.com/
