Attaching a thick border to a round table top
« back to Joinery forum
Forum topic by Will Merrit posted 09-11-2017 10:04 PM 1148 views 0 times favorited 15 replies Add to Favorites Watch
View Will Merrit's profile
Will Merrit
86 posts in 945 days
09-11-2017 10:04 PM
Topic tags/keywords: top table border edge round
Hey there, I need some help.
I have been commissioned to build a table like the one in the images below. It will be 60” in diameter and I am intimidated about that border on the table top. Do any of you have ideas of how I should go about adding that border on there? It will be about 2” thick and need to be about 3-4” inches wide. I should also mention I am a bit perplexed as to how to do the 4 quadrants also on the top. Bit off more than I can chew at this point, but hey thats why I have you guys right!
15 replies so far
View papadan's profile
papadan
3584 posts in 3420 days
#1 posted 09-11-2017 10:46 PM
The last picture is poorly stained Pine. You can just cut your pieces out of 2 by lumber. As for the four quadrants…edge glue 2 by boards and cut it round. Then just cut it into quarters. Add in the spacers and edges. Seal the wood good before staining to prevent the blotchy finish.
View Loren's profile
10476 posts in 3699 days
#2 posted 09-11-2017 11:07 PM
If you want to do it right the quadrants should
be floating panels. I’d be tempted to make the
cross, assemble the border around it and rout
a deep rabbet for the quadrants. Rout a
corresponding rabbet on the quadrants and
drop them in… use washers or something to
stop them falling out.
The border circle can be laid-out by building
an octagon around the cross. I suppose you
could glue it up like that and jig saw the
curves. Either that or draw the circles, take
it apart and band saw the curves then put it
back together. Either way you’ll have saw
marks to smooth out.
You could also do something like inset the
cross into the quadrant.
View cabmaker's profile
cabmaker
1738 posts in 2860 days
#3 posted 09-11-2017 11:12 PM
Do you have a bandsaw, what size and make ?
The project shown is pretty basic stuff
lets assume your gonna use a 4 inch wide band ,,,,,,That leaves you 52 inches for ply, template or whatever
that means the axis will be set for a 26 in radius
The same 26 R will do for your inside band cut
30 in to axis for the outside band edge.
The rest is too easy to try and explain
Enjoy the journey !JB
117160 posts in 3628 days
#4 posted 09-11-2017 11:34 PM
If this is a commissioned piece I have to differ with the previous statement about using 2×4s many people would think that you use construction grade material but it would have way too high of moisture content and create a big wood moving problem. Depending what kind of material your customer is expecting you may want to use poplar or thick pine either one needs to be kiln dried You will need to have joinery for the perimeter if just glued together it won’t hold up because end grain makes for a week joint by itself.
You could just boards glued together for the solid top with a number of cut the whole top with a trammel and router and then just make another groove for the inside diameter then you won’t have to deal with a separate outer edge.
The inside “X” could be made with a router also.
https://www.youtube.com/watch?v=g1WmOJmHId4
Edit
looks Like I was typing the same time as some of the others.
Will Merrit
#5 posted 09-12-2017 01:39 AM
Sounds like I should have mentioned that I will be using kiln-dried Cypress. There is a possibility that I use some Basswood but it is kiln-dried also. I was also thinking about doing the floating panels but that is something I have never done either. I am interested to know how I should go about doing the trim around the edge. I have seen people use the octagon and then cut it out however it seems like there could be too much margin for error by having to cut the inside diameter first and making it match exactly the round table top portion. Also would the floating panels need a corresponding mortise that they fit inside of on the outer band? I do have a bandsaw an old Rockwell with a 2 horsepower motor.
View jonah's profile
jonah
1768 posts in 3350 days
#6 posted 09-12-2017 01:42 AM
I would inset the cross. A clamped on straight edge, a straight bit, and a plunge router will do the trick.
Cut the outer circle in sections and attach it like you would a breadboard end. You’ll want to make it a teensy bit large and use a hand plane to fine tune the joints.
View jbay's profile (online now)
jbay
2420 posts in 951 days
#7 posted 09-12-2017 02:48 AM
#8 posted 09-12-2017 03:00 AM
If you want to do it with floating panels, do it just like Jbays drawing.
Looks great J wish I could do drawings like that,or the drawing that was there.?
jbay
#9 posted 09-12-2017 03:08 AM
- a1Jim
I removed it because I figured I would get slack about wood movement.
#10 posted 09-12-2017 03:18 AM
It’s up to you “J” but there shouldn’t be that big of an issue with wood movement with floating panels.
I for one thought it was a great aid for Will and or anyone else that want’s to make this style of table the right way.
Will Merrit
#11 posted 09-12-2017 05:05 AM
Edit:
Jbay great illustration. Thanks a million. Now to work out the circle stuff…..scary
Will Merrit
#12 posted 09-12-2017 05:21 AM
Jbay,
1. I am thinking the easiest route for me would be to glue up enough boards to get the full.table from. 2.Then using a circle jig cut the circle out of the glued top.
3. Using math (having my engineer buddy do it) figure out the measurements for the octagon. Cut them al out.
4. Lay the circle top on top of the octagon and trace.the.circle out. Then using my plunge router cut the inside circle out of the octagon.
5. Then extend.the jig and cut the circle on the outside of the octagon.
6. Take individual pieces and create a tounge on the inside edge.
7. Using router cut the matching groove all the way around the table top.
8. Fit the pieces in and glue all round. Throw a ratchet straps on for good measure.
How exactly would you go about getting the circles established.
On the cross piece. To be done before making the border
1.use router to cut away a dado 4”wide and 1/2” deep for the crossing boards to lay in.
2. Clean up miters with chisel and gule down the boards.
  • The cross piece will be old dry heart pine glued down to Cypress. Will there be any issues with that you forsee.?
Thought?
View AlaskaGuy's profile
AlaskaGuy
4252 posts in 2360 days
#13 posted 09-12-2017 08:55 AM
Thank you for sharing this useful post
animeyt | kissanime
- jennietodd141
What are these links to, is it spam?
View Mikesawdust's profile
Mikesawdust
325 posts in 3090 days
#14 posted 09-12-2017 11:14 AM
I think I would use veneered ply for the panels and frame it with the rest, this would minimize any movement and allow you to have a flush top without places to collect dust and dirt. The panels could be trimmed with a router and inset in slots for a flush top. The outer rime, I would recommend at 18 pieces with joints on the long faces creating 20 degrees between; this would be a painstaking glueup but would leave no end grain on the edges and should be stable in all directions
-- You never cut a piece to short, you are just prepping that piece for a future project
View RRBOU's profile
RRBOU
176 posts in 2343 days
#15 posted 09-12-2017 11:30 AM
I built one of those tables back in high school. I used Walnut for the main table then used 1/8” x 2” strips of curly maple. I glued them on 1 strip at a time to make glue up easier. The table is still in use by my mother after 30+ years.
-- If guns cause crime all of mine are defective Randy
