New Adventure for me....Some Questions
Forum topic by Gene Howe posted 01-24-2011 07:10 PM 1404 views 0 times favorited 23 replies Add to Favorites Watch
View Gene Howe's profile
Gene Howe
10126 posts in 3334 days
01-24-2011 07:10 PM
Recently, I acquired about 100 HO cars and engines.
Just beginning the process of acquiring track and controllers.
Eventually, I’ll want to build buildings and scenery. If possible, I’d like to avoid the expense of micro woodworking machines.
My question to you all is, do you think it’s possible/advisable to machine 1/8”-1/4” wood like balsa to the tolerances needed for small, detailed projects with a full sized table saw (Shopsmith)? What saw blades would you advise. I can only use a 5/8 arbor.
My shop has a router table for a Dremel, another router table with a 3 HP router, small strip sanders, but no small disk sander, a band saw, a Delta 16” scroll saw, a lunch box planer and a “V” sander that does a good job of thickness sanding.
If any of you folks have done any model work, PLEASE chime in.
Thanks, everyone!
23 replies so far
View crank49's profile
crank49
4029 posts in 2877 days
#1 posted 01-24-2011 07:51 PM
Dremel with router table, band saw, scroll saw, disk sander and “V” sander for thicknessing are about 99% of what you need. Some nice handtools like fine toothed back saws (dovetail and/or tennon saw(s) or a small Japanese Dozuki), a razor saw, chisels, low angle block plane, perhaps a small model makers plane and a good set of Xacto knives and some small rasps cover about all the tools I can think of that you might need. I haven’t done much RR modeling in several years, but I work on small scale detail work all the time as a Jeweler, jewelry pattern maker and I also have been into RC airplane modeling.
View canadianchips's profile
canadianchips
2600 posts in 2903 days
#2 posted 01-24-2011 08:04 PM
I’d use your bandsaw before the table saw.
The dremmel tool is a great little machine for minitures as well. I built my entire farm yard at 1/64 th scale many years ago. I did purchase a small disc-belt sander while doing that project.
View dbray45's profile
dbray45
3310 posts in 2682 days
#3 posted 01-24-2011 09:07 PM
I once built a large HO train layout – for making ties I used a scroll saw, make a mini sled to make your life easier. Everything else use basswood and a razor saw. For “rotten” ties, use balsa wood, distresses easily and looks good. For scenery, use hydrocal instead of plaster if you can get it, very strong and can make it very thin – papermache thickness can almost stand on.
Also check out http://www.micromark.com
-- David in Damascus, MD
View swirt's profile
swirt
2549 posts in 2878 days
#4 posted 01-24-2011 09:14 PM
Get a Zona razor saw with the little aluminum miter box for crosscuts
Gene Howe
#5 posted 01-25-2011 02:03 AM
Thanks to all of you who replied with some great suggestions.
I think I have a pretty good idea of what I need.
Thanks again.
View Sarit's profile
Sarit
549 posts in 3045 days
#6 posted 01-25-2011 02:26 AM
You can easily cross cut 1/8” balsa wood with razor blades. I used to do that when I was kid for a school project. You can a the end of a piece of L channel aluminum as a “miter box” make square cuts.
View Napaman's profile
Napaman
5526 posts in 3983 days
#7 posted 01-25-2011 03:11 AM
just curious——what are HO cars? Train sets???
-- Matt--Proud LJ since 2007
canadianchips
#8 posted 01-25-2011 05:40 AM
“ho scale” is a railroad set. 1/87 scale.
dbray45
#9 posted 01-25-2011 06:49 PM
Is it possible to create and and post a list of mills that ship with web addresses. This could help all of us. If this could include various countries, it would be a great resource for all. I have looked on the web and got really odd results but there are a lot of people that have worked with these mills. If we do create a post for this, make sure you check with the mill first and find out if they ship
Just a thought.
View Belg1960's profile
Belg1960
1060 posts in 2971 days
#10 posted 01-25-2011 11:57 PM
Gene, you have found one of the best sites for reference in Railroad-line.com, I have been a member of that forum for about 6 yrs and watched in the wings for several more. My interest in MRR leans towards building structures and dioramas. I have found that if you are looking to build a layout or build structures, just like in woodworking quality tools make the difference, but that is not to say that the person doing the actual modeling has a big part of creativity and craftsmanship just like building our projects here. If there are any direct questions you have I will be very happy to help if I can and if I can’t I can steer you to the right person on the RRline forum.
I know many people swear by Micromark and I like their stuff as well but their prices are not the greatest. For what you are describing the tools you have will be overkill, not to say the tablesaw or band saw could not be used but to give an example for a scale 2×4 it comes out to .023” x .046 so to cut this small the waste from both of the larger tools would be more than what the actual final dimensioned piece would be.
I currently looking at making myself a manual cutter to slice my own scale lumber from basswood or maybe even balsa. Again if interested contact me offline or here if the host doesn’t mind us discussing on the forum. Pat
PS By the way MRR is my favorite hobby with woodworking a very close second.
-- ***Pat*** Rookie woodworker looking for an education!!!
dbray45
#11 posted 01-26-2011 12:21 AM
I will have to look at this
View Dennisgrosen's profile
Dennisgrosen
10877 posts in 3021 days
#12 posted 01-26-2011 12:43 AM
I have nothing to do with other than a happy costummer
and I don´t think you will regret buying the brand
and most of there miniature tools are made to cut industrial spec.
take a look at proxxons tools they have from dremel kinds of tools to microtablesaws
its a german tool factory
here is the Danish site
http://www.proxxon.com/dk/
and here is the com site
good luck with your new Hobby :-) making diorama´s is a great creative hobby
Dennis
Gene Howe
#13 posted 01-26-2011 02:45 AM
Thanks for the links, Dennis.
Neat stuff, for sure.
View Pop's profile
Pop
427 posts in 3852 days
#14 posted 01-26-2011 07:10 PM
I’v sold Proxxon. Super good stuff, but pricey. I built several display HO gauge layouts at my 1st job out of high school (class of 59) a toy store. Since then I’ve built several architectural models. Most were 1in. = 50 ft. some were real buggers like the positive model of a power plant hollowed out of a mountain. My last was a 1/2 in. = 1 ft. of a proposed shop. Not a lot of detail but lots of fun. I’ve never had miniature machines. A 1/8 in. blade on my bandsaw, Get yourself a Shopsmith 1-1/4 in. blade arbor & a hollow-ground blade. Also buy a blank insert to make a zero clearance saw insert. This set up is what I use on my Shopsmith for fine work. The hollow-ground blade is a steel blade on carbide teeth & made for small work. I have a big assortment of Xacto knives & both Proxxon & Foredom rotary tools. I’m not saying run out and but these things today but they do come in handy.
Pop
-- One who works with his hands is a laborer, his hands & head A craftsman, his hands, head & heart a artist
View Pop's profile
Pop
#15 posted 01-26-2011 09:26 PM
What I meant to say was a steel blade without carbide teeth. Most of model making is figuring out what to use to represent something. My scroll saw & band saw were the main cutting machines I used for most modeling operations. After that xacto knives & razor saws. I had to end my earlier comment before I was through. Here’s a couple of photos of the proposed shop model 1/2 in. = 1 ft..
1st. shop layout. Reworked it.
Yep! That little gut at the work bench is me.
All the ittey bitty machines & shop furniture.
Oh! Bi-the-way I’ve got to build another one this summer. There’s been major changes in size, design & machines
Pop
