Sanding carvings
« back to Woodcarving forum
Forum topic by a1Jim posted 09-11-2017 07:22 PM 1013 views 0 times favorited 11 replies Add to Favorites Watch
117091 posts in 3574 days
09-11-2017 07:22 PM
Topic tags/keywords: question
Hi everyone
I’ve been working on a pie crust tilt top table for years part of the problem is that This was my first project with what I consider a good amount of carved details. After many hours of sanding, I’m still doing one more sanding before I start the finishing process but I’m finding it hard to sand around smaller details.
Over the many months of sanding, I have use jewelers files, trimmed emery boards, sanding cords and small burrs.
Now I’m still searching for more sanding tools to make it easier for the small details. I’ve ordered these ,let me know if you’ve used these or if you have a better Idea.
Thanks for your help
Jim
https://www.amazon.com/gp/product/B00004YYDG/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B00004YYD2/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B073D9WK9H/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
https://www.youtube.com/watch?v=kBWUL71lo1Y
https://www.youtube.com/watch?v=CHDcAcLTXb4
11 replies so far
View Texcaster's profile
Texcaster
1281 posts in 1671 days
#1 posted 09-11-2017 09:45 PM
Jim, generally, in good carving, the job is right off the tool. Sanding blunts all the crisp edges. Sanding is a four letter word. lol
I usually sand my archtops but I’m moving to a primitivo look for awhile.
-- Mama calls me Texcaster but my real name is Mr. Earl.
View robscastle's profile
robscastle
4989 posts in 2201 days
#2 posted 09-11-2017 09:55 PM
Jim,
I saw Nick Agar of King Arthurs tools, KA Tools using a bristle brush on some driftwood, it may be of help,
its at about 3:35 or so, mind you the whole video is interesting if you are not familiar with the KAT series.
Camelot and King Arthurs Tools is actually a USA not a UK product, very odd!!
https://www.youtube.com/watch?v=g1WmOJmHId4
No doubt you have a die grinder already.
-- Regards Robert
#3 posted 09-11-2017 09:55 PM
I’m afraid it’s it’s a little late for that on this project Earl but I really would like to carve the proper way. I have signed up for Mary May’s online emails but started this project years before with a power carver.
6855 posts in 3977 days
#4 posted 09-11-2017 09:58 PM
Hey Jim, not trying to be a stick in the mud but if you’re sanding the carving, your chisels need to be sharpened. Sandpaper won’t give you the polished surface a chisel will.
#5 posted 09-11-2017 10:02 PM
Thanks Rob Iook own a Arbortech cutter for my side grinder but this project took a little more refined tools ,at least for me.
View mpounders's profile
mpounders
875 posts in 2892 days
#6 posted 09-11-2017 10:03 PM
I have used all of these except for the last one. The split mandrel is really handy and easy to use with different grits of cloth backed paper. The paper sanding cones are very useful for me. They are not overly aggressive and I use them in this size and the smaller ones on my carvings. Use both of these on something with variable speed or foot pedal control. The fuzzy wheels are ok, but can discolor lighter woods, so I don’t use them as much. You might look at the 3m scotch-brite radial bristle discs that are also available in various grits. How aggressive they are also depends on how you use them, but they might be useful for you.
-- Mike P., Arkansas, http://mikepounders.weebly.com
View Loren's profile
10384 posts in 3645 days
#7 posted 09-11-2017 10:15 PM
I have some “tadpole” shaped sanding pads
that are pretty useful.
Like these, though that’s not the set I have.
#8 posted 09-11-2017 10:26 PM
Good to hear from you Lee ,I understand that now actual carving chisels would have been the way to go. but I was using a power carver on this project I can see after this experience I realized all that sanding would not have been necessary.Remember this is my first real carving,
#9 posted 09-11-2017 10:30 PM
Those look very interesting Mike thanks alot.
Thanks, Loren I forgot to mention I had a bunch of tadpoles, they do come in very handy.
View ClaudeF's profile
ClaudeF
656 posts in 1704 days
#10 posted 09-11-2017 11:15 PM
Like Mike P., I often use the 3M bristle disks in my Dremel. I don’t sand with them, per se, but use them to get the fuzzies out of the cut lines. A single disk on the arbor will get most of the fuzzies out. Where it’s too confined for the disk, I use one of several small diamond burrs, such as https://www.woodcraft.com/products/diamond-tip-carving-burr-set-120-piece
Claude
-- https://www.etsy.com/shop/ClaudesWoodcarving
#11 posted 09-11-2017 11:49 PM
Thanks for your help Claude, I do have a boat load of burrs but for the small pearl beads they are either too big or I don’t have a steady enough hand for use with my Foredom
