Newbie question about drum sand vs planer
Forum topic by gdiddy13 posted 09-11-2017 06:57 PM 330 views 0 times favorited 4 replies Add to Favorites Watch
View gdiddy13's profile
59 posts in 675 days
09-11-2017 06:57 PM
Can someone explain the basics of a drum sander, meaning how it compares to a planer?
I have a planer, but have to make adjustments to my pieces due to bows, twists, etc.
Then I saw others running live edge or cutting boards through drum sanders and getting it dead flat on one side with no adjustments. Is this right? Why wouldn’t I buy a drum sander instead of a planer.
I understand that a planer makes one side parallel to the other, but does a drum sander not do that?
Thanks guys!
View papadan's profile
3584 posts in 3300 days
#1 posted 09-11-2017 07:04 PM
Drum sander does the exact same thing as a planer, just at a much slower pace and shallower cut. To flatten a board, you need to shim under it where it does not touch the surface.( of a flattening sled) to keep it steady through the planer or sander. When one side is flat, take it off the sled and run it through to flatten the other side. A good planer will give you a finish ready surface just like a drum sander will.
View splintergroup's profile
1928 posts in 1154 days
#2 posted 09-11-2017 07:11 PM
Consider a sander like a planer with much finer control over the cut, but the cut can not be nearly as aggressive as a planer provides.
A sander excels at gnarly grain (no tear out) and as you noticed, end grain.
Where a planer will force the bow out of a board as it gets pressed flat by the rollers, a sander has much less aggressive down pressure and a bowed board will result in snipe unless a sled and shims are used.
I own both. I rarely use the planer except for getting close to final thickness. I use the sander if I’m within 1/8” or so of final thickness. A few passes with 36 grit paper can quickly get me down to a few 0.01’ths where I’ll use finer grits.
I also tend to remove minor twist/bow on the sander with a sled and shims.
4906 posts in 2425 days
#3 posted 09-11-2017 08:06 PM
What they said, and if you opt for a sander instead of a planer plan on multiplying your shop by a factor of 10 or more to get the same work done. Sanders are nice, but they are not a substitute for a planer.
View bbasiaga's profile
1158 posts in 1926 days
#4 posted 09-11-2017 08:21 PM
Normally to flatten a board you need a jointer and a planer. I did not think a drum sander could serve both functions any better than a planet can (there are ways to joint on a planer).
The big advantage I see is that the drum sanders are able to do wider boards at a lower cost than wide planers.
