Bandsawed Veneer - How to install
Forum topic by Bohaiboy posted 09-10-2017 05:53 PM 783 views 0 times favorited 12 replies Add to Favorites Watch
View Bohaiboy's profile
Bohaiboy
76 posts in 1992 days
09-10-2017 05:53 PM
I have decided I want to cut some mesquite veneers on my bandsaw. I am thinking about cutting 1/8 or 3/16” think to allow for sanding. I have a Performax 16-32 sanded so not an issue. My question is what is the best way to install this thicker veneer. Most video demos are for the VERY thin veneers that are available commercially. I did find a video by The Wood Whisperer for jointing pieces side by side to form a “larger” sheet, but not sure if that is better than adhering sheets (mine will be 5-6” wide) individually to the base stock. Any suggestions welcomed.
Thanks all from finally drying out Houston.
-- Tim, Houston, TX area
12 replies so far
View AlaskaGuy's profile
AlaskaGuy
4766 posts in 2507 days
#1 posted 09-10-2017 06:51 PM
Never mind.
View Loren's profile
10477 posts in 3846 days
#2 posted 09-10-2017 06:58 PM
Use a veneer press or vacuum bag.
Bohaiboy
#3 posted 09-10-2017 08:29 PM
I would if I had one, unfortunately I don’t. Also what is the preferred glue for the thicker veneers? Someone mentioned Google search, well after about 10 videos on how to glue the super thin veneers, I gave up and came to experts. Plenty of videos on how to cut veneers but I can do that part without issue.
View Rich's profile
Rich
3873 posts in 787 days
#4 posted 09-10-2017 09:44 PM
Both plastic resin glue and liquid hide glue will do the job and give you plenty of open time to work. You will need some sort of press but it can be as simple as a couple of platens and some cauls — all things you can make in the shop for cheap if you don’t already have them lying around.
View shipwright's profile
shipwright
8163 posts in 2996 days
#5 posted 09-10-2017 10:45 PM
At 1/8” to 3/16” you are almost not talking about veneer. I use thick veneer (1/16”) for marquetry and at this thickness, which is very thick by commercial standards, you can still hammer it with hot hide glue. I would want to experiment before I recommended it on 3/16” however.
Hammer veneering is a great way to beat the “no press, no vac bag” problem. I’m just not sure if it will fly with what are probably more correctly “thin boards”.
Here’s an example: http://lumberjocks.com/shipwright/blog/36014
Bohaiboy
#6 posted 09-10-2017 11:00 PM
Paul, thanks. I assume that is you in the video. What thickness would you cur your veneers (5-6” wide each) to accommodate sanding prior to glue down? I also noticed in that video that the substrate was boards vs plywood or mdf. Are you worried about wood movement of the substrate at all?
shipwright
#7 posted 09-10-2017 11:45 PM
Actually the substrate is a cold moulded hatch cover so it is (albeit home made) .... plywood.
I normally cut pretty close to 1/16” because the species that I cut myself are often expensive exotics. I use a Lennox Trimaster carbide blade and it gives a very nice cut.
This blog covers my latest veneer cutting. It was in My winter place in Az so I’m using my ShopSmith bandsaw.
http://lumberjocks.com/shipwright/blog/104226
The Tulipwood I’m cutting was ~$125 / board foot so I really didn’t want to do a lot of sanding. :-)
View TungOil's profile
TungOil
1057 posts in 693 days
#8 posted 09-11-2017 12:46 AM
Paul’s advice is the best to follow.
If you want to see how I did thick shop sawn veneers for the dining table I’m building take a look at my blog here:
http://lumberjocks.com/TungOil/blog/archive
entry # 5 through 8 show how I made mine.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
Bohaiboy
#9 posted 09-11-2017 12:49 AM
I can get Tulipwwood from our local supplier at $45.00/BF for 4/4 if you ever need some shipped.
shipwright
#10 posted 09-11-2017 05:37 AM
- Bohaiboy
Is that trimmed or live edge with lots of sapwood? There were lower prices when I bought mine but they would have had a lot of waste. This was trimmed to just heartwood. Still that’s a lot cheaper than even the live edge stuff I was looking at last winter.
Here is what mine looked like.
Sorry, I don’t mean to hijack the thread. :-)
Bohaiboy
#11 posted 09-11-2017 02:33 PM
I am not sure. I just have a printed price list. Usually they have really good wood. It only states 4/4 rough. The store is Houston Hardwoods. http://houstonhardwoods.com/ I buy a majority of my wood there. We are very fortunate in Houston area, we have 4 major wood retailers here with many exotics available. Plus we have a Woodcraft and Rockler store that has some wood, albeit generally a lot more expensive. Most of the retailers here also have S4S in some exotics too.
shipwright
#12 posted 09-11-2017 07:34 PM
Thanks, I’ll file that info. It’s not far away when I’m in Az.
