Box joint with single blade on a table saw
Forum topic by BasHolland posted 01-24-2011 09:03 AM 5289 views 0 times favorited 3 replies Add to Favorites Watch
View BasHolland's profile
BasHolland
98 posts in 2585 days
01-24-2011 09:03 AM
Topic tags/keywords: boxjoint single blade table saw question joining
Hello woodworker-friends,
I’ve been searching and searching the net on finding an answer for this question:
Can I make Box-Joints on the table saw with a single blade? (I don’t mean finger joints, but the “wider” pins and tails.)
I coudn’t find the answer.
In Holland and even Europe (I guess) the Dado-blades are very rare. So, If I want to make a box-joint, I have only a single blade. I didn’t find any jig on the internet or here on LJ’s.
Maybe someone’s got an Idea?
Thanks a lot.
Bas
-- Bas, Holland
3 replies so far
View crank49's profile
crank49
4029 posts in 2874 days
#1 posted 01-24-2011 11:01 AM
I have mounted two identical blades on the table saw with a thin shim washer between to make 1/4” box joints. You just have to position the blades so the teeth are stagered. The two blades have to be identical and it’s best to have less than 40 teeth, like a rip blade, so there is room to clear out the chips and dust. I don’t see why you couldn’t put more washers in between to make up to a 3/8” kerf, but you would have to clean out the waste in the middle with a chisel. There is a set of blades on the market here in the USA that is made just for this purpose.
crank49
#2 posted 01-24-2011 11:18 AM
Another method is a little jig called a kerf maker. Search on here for other posts about it, or you can buy them. This link shows one that is sold by Bridge City Tool Works.
http://www.youtube.com/watch?v=PQ6_S6lZKLI&feature=player_embedded
BasHolland
#3 posted 01-24-2011 01:36 PM
Thank you crank49 for your quick reply.
The video explains a lot.
Now I understand why here on LJ’s the kerfmaker is “much” discussed. I’ve seen a lot of shopmade ones.
I’ll give it a try.
Thanks again.
Bas
-- Bas, Holland
