So How Accurate is Acceptable on My CrossCut Sled?
Forum topic by Dwain posted 09-09-2017 06:55 AM 4787 views 0 times favorited 24 replies Add to Favorites Watch
View Dwain's profile
Dwain
556 posts in 3944 days
09-09-2017 06:55 AM
Topic tags/keywords: cross cut sled table saw accuracy
So I recently put together a large crosscut sled (30” x 36”) for my table saw. I made a smaller one (24” x 18”) and find it indispensable for small work. I thought a large one would be a great addition.
So I was trying to square it up tonight using the William Ng version of the five cut method. After my fourth run, I got down to .0048. My small cross cut sled is down around .0025 and I find no reason to change it. So I guess I’m looking for advice via multiple choice options. Is it:
1) Very good, no reason to get any better
2) OK
3) Good enough to get by
4) Not good enough.
I appreciate your feedback. Thanks in advance.
-- When you earnestly believe you can compensate for a lack of skill by doubling your efforts, there is no end to what you CAN'T do
24 replies so far
View gmc's profile
gmc
56 posts in 2241 days
#1 posted 09-09-2017 11:50 AM
Unless you build stuff 50’ or longer I wouldn’t lose sleep over it. .01 is better than they could do 50 years ago. Look what they built. Good Job on sleds.
-- Gary, Central Illinois
View Bill White's profile
Bill White
5009 posts in 4045 days
#2 posted 09-09-2017 01:15 PM
Stay with what ya got. You can get that much run out with a saw blade. I would not sweat it at all.
Bill
-- bill@magraphics.us
View Rich's profile
Rich
3349 posts in 674 days
#3 posted 09-09-2017 02:04 PM
Is the 0.0048 the error over the length of the fence? Assuming your pivot distance is maybe 34”, that’s a really good number. If it’s 0.0048 per inch however, that’s pretty high considering that you’ll be using it for wide stock. Over the width of a 28” board you’d be off 0.13 inches. I’m also assuming it’s 36” wide by 30” deep, so switch the numbers around if that’s backwards.
Edit: I posted about this one I built a few months ago. I like to put them together incrementally, working off of available guides on the saw. I used the fence to align the base to the runners. Then, I used a carpenter’s square that I know is dead-on and pinched the short leg between the fence and the side of the sled base, and used the long leg to align the fence. Got lucky and it was very accurate first try.
View rwe2156's profile
rwe2156
3034 posts in 1565 days
#4 posted 09-09-2017 02:18 PM
1/64” over 12” is accurate enough for ww’ing.
Once you start talking .00_ you’re into machining tolerances.
I’ve watched Ng and Spagnolo IMO its a bit anal.
Dwain
#5 posted 09-09-2017 02:34 PM
Rich,
Thanks for the note. That number is over the entire pivot distance, not per inch. Thanks for your note and the link. It’s great stuff!
View waho6o9's profile
waho6o9
8295 posts in 2662 days
#6 posted 09-09-2017 02:35 PM
Cut a big square of ply and measure the diagonals, if they’re the same you’re good to go.
Me thinks you have NASA quality sleds, good job!
View splintergroup's profile
splintergroup
2206 posts in 1307 days
#7 posted 09-09-2017 02:51 PM
That’s plenty good!
Id’ make a crosscut using the sled, maybe an 8” wide piece. Place a trusted square across the cut and see if it lies flush. full contact? you’re set to go!
View Aj2's profile
Aj2
1585 posts in 1883 days
#8 posted 09-09-2017 03:15 PM
I also think it’s good.
Unless your builds look like this
then you might need a adjustment.:) :)
-- Aj
View ArtMann's profile
ArtMann
1009 posts in 901 days
#9 posted 09-09-2017 03:57 PM
I’ll bet that if you repeated the test in the exact same way, you would get an answer that is different by 0.0048” or more. You are going past the accuracy that you can reasonably hope to accomplish with that procedure. By the way, how did you get a reading that goes down to the 1/10,000 of an inch?
woodbutcherbynight
5491 posts in 2494 days
#10 posted 09-10-2017 01:09 AM
Wood can expand and contract at greater amounts than that. My 2 cents worth is that it is sufficient for woodworking. Now if we are talking spaceships and such no keep working on it…................
Dwain
#11 posted 09-10-2017 03:39 AM
Art,
Thanks for your note. I just realized when reviewing your question that I may have made a mistake. Here, you can check my math. It is entirely possible that I did something wrong. Heck, it’s probably very likely! Anyway,
Measurement of front end of cutoff: .434
Measurement of back end of cutoff: .44
Difference: -.006
-.006 divided by 4: -.0015
-.0015 divided by the length of the cut off (9.875): -1.5189
-1.5189 multiplied by the distance between the pivot point and the end of the fence (31.5”): -.00478
I realize that the .0048 is a negative, not a positive number. I’m not sure if I would do anything with this either, provided my math is correct. Please let me know if I am doing something wrong.
Thanks for all your advice!
Dwain
#12 posted 09-10-2017 03:40 AM
AJ2,
If I could make furniture like that, I wouldn’t worry about a cross cut sled either! I’d just be happy to make such cool pieces!
View Rich's profile
Rich
#13 posted 09-10-2017 03:54 AM
Your math is correct. The negative number only means that the fence is forward of square and if you were to try to adjust it, you would move it 5 thousandths back. That’s the sort of accuracy you’re looking for in the first place though, so I’d leave it alone.
Dwain
#14 posted 09-10-2017 01:42 PM
Thanks Rich! Glad to hear I don’t need to touch it again!
View Guy's profile
Guy
23 posts in 83 days
#15 posted 05-28-2018 04:21 PM
Dwain and Rich I have a question for both of you. I am new to Lumberjocks although I have visited the site many times. I have recently built my first cross cut sled. I have a saw stop jobsite saw. I have a small work space. I am having trouble getting my fence square. I followed William NG’s video. I have gotten my fence to within .001 and then add the rest of the screws to lock down the fence and then when I run my next piece it is out by .010 or more. I go back through the process and re-adjust and think I am ok just to have the same problem. There have been several times that I followed his directions and adjusted the amount it says only to be out the other direction that much or more. I’ve rebuilt my sled a couple of times now. Not sure if I am making the mistake or if it is the runners or the miter slots. Anyway I am super frustrated at this point and need a solution as a project that I am working on will require the sled to finish it up.
