Buid a table
Forum topic by bandit571 posted 01-23-2011 08:27 PM 1008 views 0 times favorited 2 replies Add to Favorites Watch
View bandit571's profile
bandit571
19997 posts in 2681 days
01-23-2011 08:27 PM
Topic tags/keywords: pine joining shaping bandsaw chisel plane modern
Wood is your choice. Mine was pine. Top is made to float over the rest of the table. Drawer front was sawn out of the front apron. Saw kerf then was filled with beading. Grain still matches across the front apron. The end aprons are set in. This is to form a box to hold the drawer. A collar was added to the top of that box, and stands 1/2” proud of the aprons. All mortises were chopped by hand. Top was curved by making a mark 1-1/2” in from the corners. Three nails. One at each mark, and the third in the center-line of the top. A thin strip of wood stretched between the nails made a line for the curve. Done on all four edges. Aprons have a “cloud” effect cut into them.
2 replies so far
View fjdavid's profile
fjdavid
28 posts in 2679 days
#1 posted 01-31-2011 07:42 PM
Nice design. did you create that or is that from a plan?
-- Frank, http://www.FDWorkshop.net or http://www.etsy.com/shop/FDWorkshop
bandit571
#2 posted 01-31-2011 11:39 PM
Modified from a plan in FWW back in the early 90s. I made a few changes to the plan as i went along.
