Donaldson Truck Filter (as dust collector) Update
Forum topic by shipwright posted 09-08-2017 11:37 PM 2318 views 9 times favorited 9 replies Add to Favorites Watch
View shipwright's profile
shipwright
8166 posts in 2997 days
09-08-2017 11:37 PM
Five years ago I posted this blog about changing my large dust collector at my home shop from bag to Donaldson truck filters. I have been more than pleased with the price and performance but I have been noticing reduced suction for the last while.
Today I removed them and cleaned a massive amount of dust and I’m sure they would have worked nearly as new
........ but ….... I was a little rough on them and managed to deform them enough to warrant buying new ones.
All fixed now and I’m still a big fan.
Here’s the update
When I wrote the original blog I wasn’t able to find the part numbers of the filters I used. I now know them to be Donaldson P181016. My setup uses two and they are now $65 CAD. and available in stock locally.
I will update the blog.
9 replies so far
117328 posts in 3777 days
#1 posted 09-09-2017 12:00 AM
Your always a very creative thinker Paul ,well done.
View DocSavage45's profile
DocSavage45
8722 posts in 3042 days
#2 posted 09-09-2017 12:27 AM
Paul,
Had a similar experience using my thien chip collector and wondering where the vacuum had gone? tore apart the DC and found a thick coating on the inside of the exhaust bag while there was still very little in the plastic bag. Once clean suction returned.
Keep us posted.
-- Cau Haus Designs, Thomas J. Tieffenbacher
View Druid's profile
Druid
1910 posts in 2995 days
#3 posted 09-09-2017 02:56 AM
Hi Paul. I’ve been thinking of adding a vacuum gauge on my dust collector input so that I can get an idea of its performance level. Have you tried any sort of indicator on yours?
-- John, British Columbia, Canada
View rance's profile
rance
4266 posts in 3360 days
#4 posted 09-09-2017 03:00 AM
Thanks for the update Paul. I re-read your whole blog series again. Superb.
View jonah's profile
jonah
1920 posts in 3498 days
#5 posted 09-09-2017 03:03 AM
One of these days I’m going to discover what Donaldson part number is an exact match for the Wynn filters. The ones you’re using seem like they have a significantly smaller diameter.
shipwright
#6 posted 09-09-2017 05:00 AM
jonah, on the off chance that you are looking for a substitute for the Wynn 35A (HF 2Hp dust collector), the Donaldson numbers are P181038 or EAF5038. I use a P181099 on my HF dust collector in my Az shop. It’s a little smaller but half the price and allows many times the air flow that the old bag did.
There is a good discussion here http://lumberjocks.com/topics/181042
John, no I have never bothered to measure. I just notice when the suction drops off and do a cleaning. On this DC this was the first time in five years and I have no doubt that had I not deformed them by excessive bashing about the cleaning would have done the trick …... :-)
View HorizontalMike's profile
HorizontalMike
7770 posts in 3114 days
#7 posted 09-09-2017 10:35 AM
Paul,
While I use a Wynn filter after my Thein top-hat separator on HF-DC, I have been able to clean the inner dust layer off the filter by occasionally beating/tapping on the filter and MOSTLY using compressed air. I am careful to keep a safe distance from the filter media as to protect it from perforation by the air. What I find is that tapping after using the compressed air actually works rather well at knocking that dust layer free and into the collection bag below.
Looking at yours, I’m not sure I see any collection bag/container below your filters. Is that correct? Or am I looking at some kind of bucket container below the filters, for the dust to fall into?
shipwright
#8 posted 09-09-2017 02:30 PM
Mike, that’s how I clean the one I use in Az.
These are up too high to reach easily that way so I took them down and tried something different. Air was likely a better idea.
I’m thinking something like a concrete vibrator would get the job done really well. .... just trying to think of something easier.
This setup has ice cream buckets under the filters. If I ever see anything in them it means the chip container needs emptying. :-)
View eflanders's profile
eflanders
318 posts in 2050 days
#9 posted 09-09-2017 02:43 PM
Paul, Thanks for the part numbers. I just posted a tip on the H.F. dust collectors that I kind of stumbled across. I did a Wynn cartridge upgrade on my Delta d.c. unit awhile back and really love the added performance but cringed at the Wynn filter cost. Thanks for the Donaldson tip and part numbers!
