Painting The workshop
Forum topic by Grinder posted 01-23-2011 07:02 PM 1403 views 0 times favorited 10 replies Add to Favorites Watch
View Grinder's profile
Grinder
23 posts in 3026 days
01-23-2011 07:02 PM
Has anyone any thoughts on types of paint for the shop. I want to paint it all white inside and was wondering if I should use a ceiling paint that is non-reflective on all surfaces, or a flat white eggshell, or maybe a semi gloss. Just wondering what some others might have used. Thanks for your time.
10 replies so far
View TheDane's profile
TheDane
5404 posts in 3631 days
#1 posted 01-23-2011 07:05 PM
I painted mine (walls and ceiling) with Kilz primer, then 2 coats of white, semi-gloss latex … the same stuff you would use in a kitchen or bath.
—Gerry
View helluvawreck's profile
helluvawreck
30765 posts in 2835 days
#2 posted 01-23-2011 07:08 PM
I have plywood on part of my interior walls and brick on part of them. I didn’t paint the brick but I painted the plywood with exterior primer coat and exterior latex. However, I’m certainly no expert but I like it. It does make the shop brighter and reflects light well.
View ducky911's profile
ducky911
237 posts in 2758 days
#3 posted 01-23-2011 08:06 PM
Hi
Mine is not painted but last year i put up two sheets of peg board that are white and now i keep trying to turn the lights off when they are not on…good thing
I would go with the semi gloss….....has anyone ever posted that there shop was tooo bright?
View Dez's profile
Dez
1166 posts in 4046 days
#4 posted 01-23-2011 08:10 PM
Semi gloss or gloss they stay cleaner, are easier to clean and more moisture resitant. Latex is fine.
-- Folly ever comes cloaked in opportunity!
13600 posts in 3309 days
#5 posted 01-23-2011 08:14 PM
wal-mart has ‘high hide’
maintenance paint
in white and off white
semi gloss or flat
i use the semi gloss
as it is washable
and for $50 for 5 gallons
it cant be beat
i lay it on thick
and don’t use a primer
haven’t had any problems with it
in 11 years
Grinder
#6 posted 01-23-2011 10:52 PM
Thanks for all the feedback. I used that Kilz Primer to start with,(excellent stuff) and will have a look at Wal-Mart and check out that “high hide”.
View gfadvm's profile
gfadvm
14940 posts in 2658 days
#7 posted 01-24-2011 07:27 AM
I painted everything that doesnt move with high gloss white,including the ceiling.This was a big improvement over the flat whit it used to be.The dust doesnt stick and it looks like I added more lighting.
View jjwoodshop's profile
jjwoodshop
29 posts in 2660 days
#8 posted 01-24-2011 07:20 PM
My shop is a two car garage. this weekend I put down flooring, and am now back to organizing, again! I dont think it ever really stops. Focusing on work-flow and layout. I enjoy all that almost as much as firing up the equipment. And after all the cleaning this weekend, I almost hate to generate more sawdust right now, it looks too darn nice!
My next steps are to insulate, drywall, then paint. I have been thinking of doing a really light (and i mean really light) grey/blue color. Basically a white but with a little color. Note this “room” funtions as more than just the shop, its the man cave, hangout room, etc.
Is going non-white just a bad idea? I have a lot of light in the shop, and natural light as well…...
-- "If you are not prepared to be wrong, you will never come up with anything original." - Sir Ken Robinson
TheDane
#9 posted 01-24-2011 08:06 PM
JJ—I don’t see a problem with adding a little color … you’re the one that will be working in there, so it needs to suit your needs and tastes.
The only reason I like the high-white semi-gloss in my garage/shop is for light and the fact that gloss and semi-gloss are easier to keep clean.
—Gerry
View IrreverentJack's profile
IrreverentJack
727 posts in 2811 days
#10 posted 01-24-2011 08:36 PM
What surfaces are you painting? Sheetrock, block, concrete, plywood? Basement or garage? If you want to paint block or concrete I’d use a cement based (cementitious) paint like Thoroseal.
Be careful with the original non-water based Kilz. Yes it does works very well, but it will make you “paint drunk” and sick faster than anything outside a body shop. Good ventilation is a priority. Seeing spots and falling off your ladder is not fun – trust me on this one. -Jack
