Which Way Do You Bore?
« back to Hand Tools forum
Forum topic by OleGrump posted 09-08-2017 04:45 PM 565 views 0 times favorited 8 replies Add to Favorites Watch
View OleGrump's profile
OleGrump
167 posts in 374 days
09-08-2017 04:45 PM
Topic tags/keywords: question
Back when I was in my “tween” years, and spending as much time as possible in Pop-pop’s cabinetmaking shop, I began learning to use a brace and bits. (Among other tools). This instilled a “habit” if you will, of clamping smaller pieces vertically in a vise and boring into the work horizontally. This is not ALWAYS possible of course, but when working material that can be clamped this way, it is the method I prefer.
The horizontal method seems to help one bore straighter than doing so vertically. (I think one somewhat unconsciously visually aligns the shank of the bit with the floor). It helps the borings work their way out of the hole and drop onto the floor instead of falling back in and clogging up the hole again. Lastly, one can easily see when the lead starts to break through on the back of a through hole, so they can reverse the piece and finish the hole, avoiding tear out.
As I watch on line videos, it seems that people most people invariably will bore in the vertical position. So, now I’m rather curious. Which way do folks here in LJ land who use braces and bits bore? I look forward to hearing input on the subject from y’all.
-- OleGrump
8 replies so far
View MrRon's profile
MrRon
4800 posts in 3273 days
#1 posted 09-08-2017 05:13 PM
I never really thought about it. I just do it in the most comfortable position. Now when driving large wood screws, I use my body weight to keep the screw driver bit from slipping by applying my weight in a vertical plane.
View Tim's profile
Tim
3812 posts in 1991 days
#2 posted 09-08-2017 05:41 PM
I watched Paul Sellers do it the way you describe, tried it, and it worked well enough that I do it that way whenever I can for the advantages you mention. One advantage of boring vertically is you can balance a try square from a few directions to check you’re dead on square. You can do the same when boring horizontally but vertically it’s a little easier.
View Ron Aylor's profile
Ron Aylor
2637 posts in 677 days
#3 posted 09-08-2017 05:53 PM
For me it all depends on for what  and where  the hole being bored. If i’m boring a series of holes to create a mortise, then it’s vertical, but if I’m boring a hole for the pin in that particular mortise and tenon joint, then it’s horizontal. But then again … I’ll most likely use my drill press  which is vertical all the time!
-- Ron in Lilburn, Georgia.  https://ronaylor.wordpress.com
View WayneC's profile
WayneC
13754 posts in 4127 days
#4 posted 09-08-2017 05:57 PM
Cool drill press.
View CharlesA's profile
CharlesA
3330 posts in 1827 days
#5 posted 09-08-2017 06:01 PM
Back when I was writing my dissertation, my wife said I did so whenever I began a sentence with, “let me tell you what I’ve been writing about this week . . . “
View Rich's profile (online now)
Rich
3032 posts in 619 days
#6 posted 09-08-2017 06:49 PM
Back when I was writing my dissertation, my wife said I did so whenever I began a sentence with, “let me tell you what I ve been writing about this week . . . ”
- CharlesA
LOL. I’ve proven myself to bore countless ways. The yawns are proof.
Ron Aylor
#7 posted 09-08-2017 10:07 PM
Cool drill press.
- WayneC
Thanks, Wayne!
View Madmark2's profile
Madmark2
379 posts in 617 days
#8 posted 09-08-2017 10:15 PM
Gravity helps when boring vertically.
M
