Older jet jj6 jointer
Forum topic by JimHinze posted 09-08-2017 01:47 PM 578 views 0 times favorited 3 replies Add to Favorites Watch
View JimHinze's profile
JimHinze
1 post in 255 days
09-08-2017 01:47 PM
I have the opportunity to buy and older. Jet jj6 jointer. It’s in good shape but needs a motor.
Anyone know. What the. Motor rpm should be and what size pulley goes on the motor. Shaft.
Pics. For. Reference
Thanks in advance
3 replies so far
View MrRon's profile
MrRon
4764 posts in 3238 days
#1 posted 09-08-2017 05:29 PM
This is a manual for a 6” Jet jointer. It should be pretty much the same as the one you want to buy. The manual says, 4800 RPM for the cutter head. Knowing the motor RPM and the cutter head RPM, you can come up with any combination of pulleys to obtain 4800 RPM, or close to; it doesn’t have to be exact.
http://content.jettools.com/assets/manuals/708457K_man_EN.pdf
MrUnix
6700 posts in 2193 days
#2 posted 09-08-2017 05:38 PM
What size pulley is on the jointer? Most likely need a 1725 (1800) rpm motor, so figuring out the motor pulley size will be easy. (See here)
View Xyzmachsquare's profile
Xyzmachsquare
1 post in 247 days
#3 posted 09-16-2017 03:28 PM
How much do these motors run? New or used
