Oops - bowl too big for Cole Jaws
« back to Woodturning forum
Forum topic by socrbent posted 09-08-2017 01:20 PM 1471 views 0 times favorited 14 replies Add to Favorites Watch
View socrbent's profile (online now)
socrbent
691 posts in 2472 days
09-08-2017 01:20 PM
Topic tags/keywords: question lathe
I am looking for suggestions. The bowl I have made is too big in diameter to reverse and mount on my cole jaws to remove the waste block and finish the bowl bottom. The segmented bowl of maple and mostly walnut has a inner diameter of 10 1/4” and a height of 8 1/4”. I have a piece of mdf that was used to help as each ring was mounted (third photo). Any ideas?
-- socrbent Ohio
14 replies so far
View Wildwood's profile
Wildwood
2478 posts in 2337 days
#1 posted 09-08-2017 02:40 PM
Would make a jam chuck with two pices of MDF or plywood glued togther with turned taper. Using old carpet or carpet foam mat to cover tapered MDF so could reverse turn with just enough tailstock support to turn away most of that waste block. Would cut or sand away remaining waste block.
Of course assume you have a center hole in the waste block already otherwise will have to play with so bowl runs true for turning
Good luck with it.
-- Bill
View Kazooman's profile
Kazooman
1239 posts in 2155 days
#2 posted 09-08-2017 02:41 PM
Beautiful bowl!
Quit thinking “lathe” and start thinking “router”. A piece of MDF with a hole in it attached to the bottom with double sided tape will support your router while you remove the waste block.
View Nubsnstubs's profile
Nubsnstubs
1422 posts in 1932 days
#3 posted 09-08-2017 03:08 PM
The MDF you already have would be sufficient. True it up, cut a step on the edge that fits the inside rim diameter, bring up your tailstock and remove all but the proverbial nub. Knock it off, sand the bottom, and complete the finish….
If you haven’t already done it, check out my website and see what I have for removing tenons. It beats any of the current holding tools on the market as it has no size restrictions, and the workpiece is safely held between centers while removing tenons….......... Jerry (in Tucson)
socrbent
#4 posted 09-08-2017 05:36 PM
Thanks guys for the responses. The router idea looks promising since I already have an outer rim true and finished. I’ll post again when progress is made.
-- socrbent Ohio
View TheDane's profile
TheDane
5550 posts in 3865 days
#5 posted 09-08-2017 09:56 PM
The router idea looks promising …
No offense intended to anyone, but a router would be the last thing I would consider. Jerry’s suggestion to use the piece of MDf you have as a jam chuck is (IMHO) be far the best and easiest option.
MrUnix
7050 posts in 2401 days
#6 posted 09-09-2017 04:30 AM
I don’t have any cole jaws or a longworth chuck and have never had a problem, or even thought about getting one… jam chucks work great and can be made for free.
socrbent
#7 posted 09-12-2017 10:11 PM
Resolution – A sharp wood chisel and some time. After due consideration I simply placed the bowl upside down on a doubled up t-shirt on my bench and slowly removed the tenon. Used no hammer – just handle carving. It took several hours and was reassuring that at no time did I risk damage to the bowl. Completed with a scrapper, RAS and manual sanding to 320 then applied walnut oil. On Thursday I plan to use the Beal system to buff and wax the bowl. Thanks for your suggestions guys. Here are a few photos of the process:
-- socrbent Ohio
View waho6o9's profile
waho6o9
8524 posts in 2779 days
#8 posted 09-12-2017 10:46 PM
Beautiful work!
View hairy's profile
hairy
2782 posts in 3734 days
#9 posted 09-13-2017 01:43 AM
Maybe a paper joint would be the way to put on the waste block?
-- My reality check bounced...
socrbent
#10 posted 09-13-2017 01:48 AM
Having no experience with paper joints, would that be strong enough for a turning of this size that was turned without tailstock support?
-- socrbent Ohio
TheDane
#11 posted 09-13-2017 02:30 AM
FWIW … I wouldn’t trust a paper joint on a piece that big. Might be okay, but a small catch could (IMHO) be costly.
View walnutles's profile
walnutles
13 posts in 399 days
#12 posted 11-10-2017 10:51 PM
I would have used a hot melt glue gun and a bit of ply wood if it was me.
A lovely looking bowl, well turned and well done on removing the tenon. Les
socrbent
#13 posted 11-11-2017 02:23 AM
Thanks Les. Here is the finished product – Click for details: Star Bowl
-- socrbent Ohio
View Jacksdad's profile
Jacksdad
212 posts in 626 days
#14 posted 11-29-2017 12:28 AM
What I did to extend my Cole jaws was I made extensions that attach to the jaws. I made 8 strips that get screwed to the jaws through the holes for the bumpers, and then a bumper gets screwed to the strip of wood.
