| Forum topic by richgreer | posted 845 days ago | 2234 views | 0 times favorited | 47 replies | ![]() |
845 days ago |
In December a lady from the church told me that the manager they normally use for the children’s Christmas pageant was broken. She asked if I could fix it. I looked at it and determined that it was not worth fixing. It had been made of pine and everything had been nailed together poorly. It looked like someone had fallen on it. The lady said “We don’t need anything fancy. I don’t want you to put much time into this. Please, just slap something together” As I thought about the project I decided that oak would be much better than pine. Besides, I would rather work with oak. Then I decided that the Xs at each end should be joined with a half lap joint. I attached the slats with wood screws (and glue), but I drilled into the wood with a 3/8” bit for the screws and plugged the hole with oak plugs (hiding the screws). Of course, I sanded the plugs flush with the wood. When it was done it looked pretty good and I was pleased with it. Then I realized that I had not just “slapped it together” as I was instructed. I think I discovered that I can’t just “slap things together”. It goes against my nature. Have any of you had similar experiences? -- Rich, Cedar Rapids, IA - I'm a woodworker. I don't create beauty, I reveal it. |
47 replies so far
#1 posted 845 days ago |
If someone asks me for a “cheap job” on something, I direct them to the nearest WalMart. -- The nicer the nice, the higher the price! |
#2 posted 845 days ago |
I think I can successfully fight the urge to be a perfectionist when the situation calls for it. Just recently I needed to replace the old, falling apart potting table on the side of my house. It’s in a place where almost no one but me ever sees it, so it is purely functional rather than decorative. Off I went to the big orange box for some ugly green treated pine and a box of deck screws, and about three hours later I had a newer and better version of what I was replacing. I had all those woodworker thoughts about countersinking and plugging screws, chamfering edges, etc., but in the end I convinced myself that time wasted on trying to make a silk purse out of this sow’s ear could be better spent on other projects. -- Charlie M. "Woodworking - patience = firewood" |
#3 posted 845 days ago |
My mother in law commisioned me to make her TV stand/shelving unit. I think that she was under the impression that I could do it in a weekend. Maybe I could if I had more than 6 months experience as a hobbiest woodworker. Maybe if I didn’t have 10 other projects on the go. I’ll get to it eventually, but it won’t be slapped together. -- Rob, Sault Ste. Marie, Ontario |
#4 posted 845 days ago |
Rich, I definitely have the same problem, at least to a degree. I will quote myself….........(-: 1) “I Cannot do Quick and Dirty AnyMore….....................got a melody?” 2) “Dirty Dancing, and Quick as well- Garden Honey Do” Now the first one is definitely a lament, I really can’t make total crap anymore. Here is a piece of junk I literally threw together, but of course it lasted 15 years, but now has been replaced. Notice that it is unfinished, the wood is splintered where I drilled holes with the old time spade bits, etc.
It has been replaced with this:
Notice the cute little oak footies, the WATCO finish, the carefully designed curves. I have subsequently added a group of punches to the rack, and I use it all the time. This is a clearly overkill. The second, well, I took some absolute junk wood, and made some very simple planter stands, and painted them. This one shows the evolution away from just slapping something together. No fine woodworking joints, but definitely designed and executed in a fashion that makes them attractive and durable.
So, no. I cannot just slap something together anymore. Probably the only place I am even coming close is the installation of my new sanding machines on a ancient built in tool bench that came with the house. It is scheduled for demotlition to make way for first class cabinets, etc. No sense in getting fancy there. I am getting a very bad case of LJ Overkill. I think it is getting worse, and is probably incurable….........(-: -- Jim, Anchorage Alaska |
#5 posted 845 days ago |
Yeah, I kinda have that problem too. I’ve only been building for about a year, so I am constantly wanting to top myself on my next project. My attitude has always been this..I never know who is going to see one of my projects, so I don’t want them to see something “slapped together”. They may not know that it was a quick fix for something and assume this is how I do all my work, then you lose a potential customer. I agree with BigTiny, if they want cheap, walmart is the place. -- "I believe that our Heavenly Father invented man because he was disappointed in the monkey." - Mark Twain |
#6 posted 845 days ago |
Sometimes slapped together is just what’s needed. Otherwise you’ll build something that looks out of place and doesn’t belong. -- "The way to make a small fortune in woodworking- start with a large one" |
#7 posted 845 days ago |
Rich: I completely understand where you are coming from. Many customers have a no idea of what is expected from the demeaning instructions they give. “Slapping something together” simply means as cheap as I can get it, but generally they expect a masterpiece. It seems they have no respect for the craftsman, his skill and his pride of work. -- Roger-R, Republic of Texas. "Always look on the Bright Side of Life" - An eyeball to eyeball confrontation with a blind person is as complete waste of Time. |
#8 posted 845 days ago |
Great question Rich. Gave it some thought. I guess I’ve reached a point in my life when I make what exactly what I want to, the way I want to make it, with the materials I want to use, and when I want to do it. I don’t make things for money, so that makes this arbitrary stance a bit easier, but when you made me think about it, that’s just the way it is. There’s a good feeling about making things that will be around a lot longer than I will. Thing is, the junk you “slap together” will be around a while too. How do you want to be seen/remembered/thought of? I don’t have enough time left to work on stuff I don’t like. I’m hardly a perfectionist. Ask my wife. But I like the challenge of making things the best I can, and learning to ever do it better. Keeps me going working on the same box for 6 or 8 weeks. :-) Thanks for the question. It’s even helped me understand myself a bit better. Hope there is no additional charge for therapy. So, from my viewpoint, your realization is very healthy. (Remember: “Life is hard. But, death is long.) Roger -- "Everybody makes mistakes. A craftsman always fixes them." (Monty Kennedy, "The Checkering and Carving of Gunstocks", 1952) |
#9 posted 845 days ago |
I generally don’t like to ‘slap anything together’ or ‘throw anything together’. If anything is worth making it needs at least a basic level of care. I don’t mean that it has to be a masterpiece obviously. However, I have probably used those terms myself. I think the terms are rather meaningless really if you think about it. I saw a project this morning where the person used the term slapped it together. It was really very nicely done. It obviously wasn’t slapped together. I think it’s just sort of a slang term to mean that it was something that you didn’t spend and inordinate amount of time on. -- If a man does not keep pace with his companions, perhaps it is because he hears a different drummer. Let him step to the music which he hears, however measured or far away. Henry David Thoreau |
#10 posted 845 days ago |
My definition of slapped together = Customer has no money for anything else or the project is of a nature that slapped together needs to be matched. A door for a shed that someone slapped together as just an example. Too much attention and it looks out of place. -- "The way to make a small fortune in woodworking- start with a large one" |
#11 posted 845 days ago |
When you build something, you put your name on it. richgreer…psst… it’s manger. -- I AM in a world of wood! |
#12 posted 845 days ago |
“Slapping together” is a relative term that varies greatly with your skill/experience level. There are some that might think your manger was indeed slapped together since you didn’t research examples of actual first-century mangers, build to accurate scale using period-appropriate hand tools, and fill it with straw grown from plants that are indigenous to that part of the world. Me, I think that’s a bit excessive. -- Robert - Visit my woodworking blog: http://littlegoodpieces.wordpress.com |
#13 posted 845 days ago |
Personally, that manager sounds like he needs to be slapped, but I am beginning to see that at the end of a project, all those little things I thought would be okay to leave alone bug the heck out of me. Brandon -- I came, I was conquered, I was born again. ἵνα ὦσιν ἓν |
#14 posted 845 days ago |
reminds me of a LumberJock story from long ago – the wife said, “I want (a box)—just a box. Don’t go making it fancy. Just give me a plain old box” ... don’t think it happened. -- ~ Debbie, Canada (http://www.execulink.com/~yohan) |
#15 posted 845 days ago |
Funny you should ask…
OTOH, for a children’s pageant, I probably would have taken more care and built something similar to yours. For something on more permanent display, I might have added even more details and a nicer finish. To answer your question, it depends on the situation or the use for me. |
| Forum | Topics |
Woodworking Skill Share
8781 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3541 |
15746 |
Hand Tools
2027 |
Jigs & Fixtures
493 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
