motor
Forum topic by gary351 posted 01-23-2011 02:34 PM 1066 views 0 times favorited 13 replies Add to Favorites Watch
View gary351's profile
gary351
97 posts in 2818 days
01-23-2011 02:34 PM
Topic tags/keywords: question
Is it wrong to replace a american made ts motor with a foreign one? I need to replace a motor on my vintage table saw because the pulley shaft is bent and there is just too much vibration. Has anyone had good luck with chinese are twainese motors they are 1/2 the cost of a repair are replacement motor.
-- A poor man has poor way's
13 replies so far
View Sawkerf's profile
Sawkerf
1730 posts in 3090 days
#1 posted 01-23-2011 03:34 PM
IMO, it would only be “wrong” if you’re doing a full-on restoration, or deeply into “buy American”. Otherwise, go for it.
View SnowyRiver's profile
SnowyRiver
51457 posts in 3502 days
#2 posted 01-23-2011 05:19 PM
I agree…if you are replacing it just to make it work, nothing wrong with using what ever motor works. If it is being restored as an antique, then you would want to stay as close to the original as possible.
-- Wayne - Plymouth MN
View oluf's profile
oluf
260 posts in 3060 days
#3 posted 01-24-2011 06:03 AM
Before you replace the motor. Turn the shaft and find the point where it is most out of round, Mark that spot on the side of the shaft. Take a large hammer and hit the shaft hard on that side. Re-check the shaft for bend and hit it some more if you need to to get it so it spins true again. Something had to hit it to bend it, so you can bend it back. You have nothing to lose. You are going to junk it anyway. It is good therapy to hit something hard with a hammer!!
-- Nils, So. Central MI. Wood is honest.Take the effort to understand what it has to tell you before you try to change it.
View cutmantom's profile
cutmantom
405 posts in 3056 days
#4 posted 01-24-2011 06:17 AM
I bent the shaft on my lawn mower by hitting some chain hidden in the grass, whacked it with a 2 pound hammer and it fixed it, probably more luck than skill but like was said by oluf you have nothing to lose
TopamaxSurvivor
18283 posts in 3697 days
#5 posted 01-24-2011 09:05 AM
Watch for a UL label. Your fire insurance may be invalid.
View Knothead62's profile
Knothead62
2584 posts in 2983 days
#6 posted 01-24-2011 05:15 PM
Check the voltage and the number of hertz. American and European are different. Make sure all the spec’s match!
View Manitario's profile
Manitario
2630 posts in 2904 days
#7 posted 01-24-2011 05:18 PM
If you do that, the terrorists will win. :)
View poopiekat's profile
poopiekat
4356 posts in 3756 days
#8 posted 01-24-2011 06:25 PM
At the Barret-Jackson auto auction this past weekend, there was a ‘61 Impala that came across the auction block with a BMW V-10 motor. The car brought in excess of $200,000…so you might be onto something there, Gary!
10476 posts in 3669 days
#9 posted 01-24-2011 07:00 PM
I’ll bet that pully shaft can be straightened. The hammer method works
but you can also try a “breaker bar” – a length of hard pipe up to 6’ long.
Clamp the motor to a tree or something and go to work with the bar.
Since the motor has it’s own power, it’s a self-contained lathe as well. You
can run the shaft and hold a file (use a tool rest) or hard sanding block
against the shaft and remove the distortion. You’ll have a smaller shaft
if you do this. I’d try to get it as straight as possible with bending it
and then if the wobble was still there try turning it down a bit using this
method.
Do make sure, if you use a file, to keep the teeth clean and run the cut
it the correct direction.
poopiekat
#10 posted 01-24-2011 07:18 PM
Loren, great idea, but I’d suggest rather than machine the shaft, why not just touch up the mounted pulley? It’s aluminum, and as long as it never moves in relation to the shaft, it can absorb the ‘touching up’ to make it run true.
#11 posted 01-24-2011 07:30 PM
I’ve had a pulley in the past where the rim wasn’t exactly aligned
with the center. I think I may have pounded it back to relatively
true. The metal near the hub is often not very thick and it’s
often a malleable pot-metal too. The pulley itself could be bent
a little to compensate for the crooked shaft.
Heavy cast-steel pulleys are a different story.
gary351
#12 posted 01-24-2011 08:04 PM
Ok thanks for the replies…I”ll try pounding the shaft back to run true. Should i remove the pulley shaft so i don’t damage the bearings? Oh by the way they are machined steel pulleys.
View mcase's profile
mcase
446 posts in 3151 days
#13 posted 01-24-2011 11:19 PM
+ 1 with Topamax on the UL label
