Fibonacci Gauge in Sketchup
Forum topic by mtnbikecrash posted 01-23-2011 12:17 AM 4498 views 0 times favorited 2 replies Add to Favorites Watch
View mtnbikecrash's profile
mtnbikecrash
31 posts in 3764 days
01-23-2011 12:17 AM
Topic tags/keywords: sketchup fibonacci sequence golden golden sequence gauge
I have been looking into and learning more about the Fibonacci Sequence to incorporate into my project designs. I typically use sketchup to make scale drawings of my projects and to provide my wife with a little “visual” so she can either approve…or not…
I got to wondering and looking around to see if there was a plugin for Fibonacci Guage in Sketchup and didn’t really find much.
Then I thought that I could just make my own. What I came up with is actually quite simple and seems to work well for me.
1. Draw a 2×30 rectangle.
2. Draw a line intersecting the rectangle at 18.54. This line represents the Fibonacci ratio of 1.618.
3. Using the Push/Pull tool, pull the rectangle out to make a 2×2x30 cube.
4. Make a component of this rectangle calling it “Fibonacci Gauge.”
5. Using the scale tool, I can scale the length of this component to any length and the intersecting line always stays at the appropriate 1.618 ratio for the Fibonacci Sequence.
I copy/paste this guide into my Sketchup drawings to guide me in different proportions and design elements.
I use this simple guage and guide lines when designing things in sketchup and it has worked quite well for me. If anyone else has a better idea, better gauge, or improvements to this idea, please post and let me know.
Thanks,
JD
-- JD - Sand Springs, OK - "You can't steer a car that isn't moving..." Unknown
2 replies so far
View Bobmedic's profile
Bobmedic
379 posts in 2797 days
#1 posted 01-31-2011 06:44 PM
Sketchup already has it in there its called the golden mean. try drawing a rectangle and go slow when you reach a golden mean the lines change.
View PurpLev's profile
PurpLev
8535 posts in 3644 days
#2 posted 01-31-2011 06:52 PM
I was going to write a plugin a few months ago, but with SU already having the golden mean built in when drawing rectangles, and the thought of using such a plugin I never got to it…
good thing about SU is that you CAN do different things to get things done – looks like you did just that :)
