Ryobi BTS20 - Will Not Heel
Forum topic by Doug posted 09-05-2017 04:37 PM 364 views 0 times favorited 5 replies Add to Favorites Watch
View Doug's profile
Doug
23 posts in 1199 days
09-05-2017 04:37 PM
Topic tags/keywords: tablesaw refurbishing ryobi bts20 heeling aligning mitre slot fence
I know a lot of folks have much better table saws than I do, but this little guy is pretty handy, and up until last month required almost no special maintenance.
The problem is I am slightly more than 1/16th off… ~3/32 off when measuring from the mitre slot from end to end.
The Ryobi manual is explicit that there are two allen bolts on the back of the blade assembly that when loosened are able to allow me to push the blade over to the correct position and re-tighten the bolts. Yesterday I tried this and it did not work. I tried again about a dozen times and got no results.
Any help from someone who has the same model? I will be upgrading in 2018 to a better saw, but until then I really do not want to be out of business.
Thanks!
Doug
-- The only limit to your skills is your willingness to learn
5 replies so far
9931 posts in 3549 days
#1 posted 09-05-2017 05:52 PM
It seems to me likely you haven’t used enough
force. Much of the weight of the saw’s internals
will be on the point that needs to move. In
adjusting cabinet saws I have reached up
from underneath to lift the entire assembly to
make it easier to shift it.
View Doug's profile
Doug
#2 posted 09-05-2017 08:44 PM
thanks will give that a try. i actually had a 2×4 backed by shims to move it when the bolts were loosened. then it just popped right back out of line after i tightened the bolts and removed the 2x. What bothers me more is what the hell did i do to knock it out of line…i’ll just settle for fixing it…
View MrUnix's profile
MrUnix
6325 posts in 2100 days
#3 posted 09-05-2017 09:32 PM
I checked the manual online and didn’t see anything that addressed aligning the blade to the miter slots… where is it? Only thing I could find was aligning the fence to the blade. Anyway, it sounds like you need to loosen more than just two screws at the back of the assembly… on most saws of that design, there are at least 4 mounting points to the table top. If only the back two are being loosened, then the others are probably preventing it’s movement. Parts diagram is horrible, and I can’t identify what bolts are holding what. I think you need to crawl up under there and see what’s going on – ignore the manual :)
View Doug's profile
Doug
#4 posted 09-06-2017 09:34 PM
yeah, i am thinking that too. there are two large screw heads on the assembly toward the rear of the saw accessible when the plate is off. I may try them too and see if that makes the difference.
The instructions in the user manual were on page 25?
View Doug's profile
Doug
#5 posted 09-11-2017 07:04 PM
The saga continues. Spoke with Ryobi tech support and they confirm only those bolts are loosened and it should move when tapped.
Tried lifting from below – and that did not help.
Going to look for what might be holding things in place – some lubrication maybe?
I see a new table saw, stepping up to a hybrid.
Will update when I figure out the right fix.
