Help, how am I going to do this?
« back to Woodturning forum
Forum topic by Jack Lewis posted 09-05-2017 02:45 AM 2013 views 0 times favorited 10 replies Add to Favorites Watch
View Jack Lewis's profile
Jack Lewis
255 posts in 1014 days
09-05-2017 02:45 AM
Help, how am I going to do this? It is about 5.25 tall. Any suggestions will be greatly appreciated. I could probably carve the whole thing but I am not a carver and don’t want to be.
-- "Now we are getting no where, thanks to me"
10 replies so far
View papadan's profile
3584 posts in 3304 days
#1 posted 09-05-2017 02:47 AM
Turn the main piece on the lathe, then start carving!
View TheFridge's profile
9112 posts in 1422 days
#2 posted 09-05-2017 02:54 AM
Pretty much.
View Wildwood's profile
2269 posts in 2070 days
#3 posted 09-05-2017 09:44 AM
Bought this book more than 25 years ago and it went out of print but guess its back now. Unless interesting in carving save your money, although he has updated his procedures with more power tools these days. Did several table lamps that sold for between $300 to $700 each.
This guy uses lots of power tools but will end up with lots of sanding.
Just learning how to mark out what want to cut big help, how you cut wood away another issue.
Good luck with it.
-- Bill
View dbray45's profile
3315 posts in 2712 days
#4 posted 09-05-2017 11:46 AM
Try Mary May’s carving courses on-line. Not hard and very insightful
-- David in Damascus, MD
View CharlesNeil's profile
2361 posts in 3806 days
#5 posted 09-05-2017 01:21 PM
I have not done it, but they turn the urn separate, they actually turn the inside profile then saw it apart turn it inside out and glue it back together then turn the out side, again base is turned separate
its called inside out turning .they do it with christmas ornaments
View builtinbkyn's profile
2068 posts in 876 days
#6 posted 09-05-2017 01:29 PM
I’ve not done it, but did view this video a while back. You may be able to modify the method to turn your shape.
View on YouTube
-- Bill, Yo! Brooklyn & Steel City :)
View ArtMann's profile
902 posts in 752 days
#7 posted 09-05-2017 04:08 PM
It can be done with a CNC router and a rotary adapter. I have also seen videos of these done with a Legacy mill. There would still be a little lathe work to do. Maybe you could find someone to help you with that particular piece.
#8 posted 09-05-2017 04:39 PM
Think that is Ernie Conover in the video and is doing single barley twist one way to it.
Started out using the same method after reading a Roy Underhill book on barley twist from the library. Think can find same info online to day if sign up to watch the videos.
If doing tapered or graduated twist need more lay out lines like pitch, segement line, and start lines. These line change with your demensions.
You need little machine coding before using a cnc router, don’t think they still sell legacy mills.
Speaking from personal experience if not willing to put in time, effort, and wasted wood don’t even bother.
-- Bill
View JBrow's profile
1342 posts in 856 days
#9 posted 09-07-2017 12:03 AM
Jack Lewis,
Nothing that I would want to attempt, but I wonder whether steam bending would be a workable approach. The bending would be easy enough, but making the bending form would be a real challenge, not to mention the joinery at the base and up top, at the finial.
View Jim Finn's profile
Jim Finn
2641 posts in 2858 days
#10 posted 09-07-2017 12:05 AM
Look into “compound cutting a spiral” using a scroll saw.
