Resawing vs. Thickness planing
Forum topic by EBatson posted 09-05-2017 01:17 AM 605 views 0 times favorited 10 replies Add to Favorites Watch
View EBatson's profile
EBatson
2 posts in 173 days
09-05-2017 01:17 AM
I have squared up and straightened enough 8/4 hickory (beautiful grain patterns) for a kitchen table top. It seems real stable now, though several pieces had some cup, twist, or bend when rough. Most pieces are at least 1 3/4” and I need to get it to 1 1/2”. I know I can plane it down without any problem. However, since it is such beautiful wood, I’m thinking of taking 3/16” veneer off most of the pieces for some future use. I have a Laguna 14Twelve, which is plenty capable, but my few efforts at resawing (no efforts at veneer) have usually wound up with the wood releasing stress and bending, so I’m hesitant. Any advice is welcome.
10 replies so far
View BlasterStumps's profile
BlasterStumps
440 posts in 311 days
#1 posted 09-05-2017 01:34 AM
Do you have an extra piece you could do a test cut on to see what happens?
View TheFridge's profile (online now)
TheFridge
8655 posts in 1358 days
#2 posted 09-05-2017 01:35 AM
You could. Your top thickness will probably be in the range of 1-7/16 to 1-3/8 after planing though.
View sawdustdad's profile
sawdustdad
350 posts in 757 days
#3 posted 09-05-2017 02:25 AM
If it’s cupped or warped, you need to joint it again, then plane to final thickness. This is common behavior when dealing with rough sawn lumber. I always mill over size and let “settle” in the shop a few days before final dimensioning.
-- Murphy's Carpentry Corollary #3: Half of all boards cut to a specific length will be too short.
View Carloz's profile (online now)
Carloz
1075 posts in 463 days
#4 posted 09-05-2017 02:50 AM
You are an exceptionally good resawyer if you can take 3/16 off and loose only 1/4 of the wood.!
View Loren's profile
9763 posts in 3519 days
#5 posted 09-05-2017 02:58 AM
Yeah, it will probably cup but you can better
your chances of getting pieces flat enough
to use if you stack and sticker them immediately,
and weigh the stack down.
View jbay's profile (online now)
jbay
1917 posts in 771 days
#6 posted 09-05-2017 03:01 AM
Unless you really needed the 3/16 pieces for something,
I would just plane them down, taking the same amount off each side to help keep the boards as stable as you can.
-- If anyone would like to see my Portfolio, PM me and I would be glad to send you the link.
EBatson
2 posts in 173 days
#7 posted 09-05-2017 10:03 AM
I decided just to plane them down. Thanks to all.
View rwe2156's profile
rwe2156
2749 posts in 1352 days
#8 posted 09-05-2017 01:51 PM
Hickory is tough to work with and moves a lot due to stress.
I suggest finding a shop to drum sand it rather than plane it.
Hickory is prone to tear out.
View ArtMann's profile (online now)
ArtMann
751 posts in 688 days
#9 posted 09-05-2017 04:02 PM
I use my Laguna 14/twelve to resaw pieces like that all the time and it works quite nicely. Your results will depend a great deal on the design and quality of the blade you use. I always cut the material a little thick so I can run it through my drum sander to smooth and bring it to exact thickness. I cut a lot of 5/16, 3/8 and 1/2 inch planks for box making and CNC carving but I have cut 1/8 inch material for inlays.
View CharlesNeil's profile
CharlesNeil
2172 posts in 3742 days
#10 posted 09-05-2017 04:07 PM
If you resaw it , odds are its going to cup, if it were me an its now flat and stable , i woul dplane equal amounts off both faces .. keeping the moisture levels balanced,
