depth of dado
Forum topic by Rob Vicelli posted 01-22-2011 05:53 AM 1087 views 0 times favorited 2 replies Add to Favorites Watch
View Rob Vicelli's profile
Rob Vicelli
104 posts in 2563 days
01-22-2011 05:53 AM
Hi, i am building some lower cabinets for my kitchen and previously for lowers I followed sommerfeld’s t&G method. For these cabinets I would like to use levelers so I will need to change my constuction methods as the T&G method will not allow the lower shelf/bottom to support the cabinet weight so I plan to dado the lower shelf into the side. What would be the correct depth and would this allow me to place the leveler under the joint of both the side and bottom?
Any suggestions would be appreciated.
-- Rob V
2 replies so far
View cabmaker's profile
cabmaker
1665 posts in 2680 days
#1 posted 01-22-2011 06:16 AM
I normally go 1/8 inch (rabbits & dados) in standard type bases. That would leave plenty for your levelers. FWIW , I once as a rule plowed 1/4 to 3/8, it only took twenty or so years to determine that was unneccessary. On some builds it is not enough however but you will be fine at that on your bases. Good luck JB
Rob Vicelli
#2 posted 01-22-2011 06:26 AM
thanks cabmaker, without your advice I would have guessed 3/8, but 1/8” it is!! thanks for the tip.
-- Rob V
