Dovetails with ply and solid
Forum topic by agianni posted 880 days ago 559 views 0 times favorited 3 replies Add to Favorites Watch
View agianni's profile
agianni
13 posts in 1190 days
880 days ago
Topic tags/keywords: maple plywood dovetail
I’m building some drawers for an entertainment unit and I was thinking about making the drawer bodies out of birch ply but the fronts out of maple and they would be joined by dovetails. Should I consider doing this? Or will the differences between the wood types cause problems with the joints? i.e. will the plywood and maple shrink and swell at different rates and cause the joints to open up? These will be 100% finished, so they shouldn’t have any serious exposure to shrinking and swelling.
-- Andrew
3 replies so far
View Darren J's profile
Darren J
2 posts in 1723 days
#1 posted 880 days ago
It’s possible you would have issues with swelling, but it probably depends on how deep your drawers are. I considered making drawers like that once, but was really concerned about chip-out of the ply faces when cutting the dovetails.
View Loren's profile
5034 posts in 1845 days
#2 posted 880 days ago
Dovetailing ply to solid woods usually works fine. Expansion and contraction
of woods usually only causes problems with bigger joints, like very long
tenons.
Make sure the maple is dry though.
View TheDane's profile
TheDane
2698 posts in 1861 days
#3 posted 880 days ago
I assume we are talking router-cut, half-blind dovetails and baltic birch?
If so, it helps reduce tear-out if you use a marking knife or marking gauge (to define the line across the stock) then do a light scoring cut before you route them.
—Gerry
