| Forum topic by Raymond | posted 855 days ago | 1685 views | 0 times favorited | 13 replies | ![]() |
855 days ago |
Topic tags/keywords: question I hate end grain. What is your best way of sealing an end grain prior to applying a finish. I have some cedar that is sucking up finish like a sponge. -- Ray |
13 replies so far
#1 posted 855 days ago |
Shellac. -- 温故知新 |
#2 posted 855 days ago |
I’ve used sanding sealer on all types of woods. May take a few extra coats then the long grain but with a little sanding between them you should end up with a surface that’s as smooth as glass. -- "At its best, life is completely unpredictable." - Christopher Walken |
#3 posted 855 days ago |
+1 on shellac…and on cedar I’d make certain it’s a thick cut. -- jay, www.allaboutastro.com |
#4 posted 855 days ago |
+2 on shellac -- Childress Woodworks |
#5 posted 855 days ago |
Shellac (dewaxed) is always a great choice because it’s compatible with anything you might want to put over the top of it. -- Jonathan, Denver, CO "Constructive criticism is welcome and valued as it gives me new perspectives and helps me to advance as a woodworker." |
#6 posted 855 days ago |
I bow down to the king—Woodwhisperer—and follow this advice. -- Kinky Friedman on gay marriage: "They should have the right to be just as miserable as the rest of us." |
#7 posted 855 days ago |
I’e heard of mixing 50% water and 50% wood glue then brushing that on but have never tried it. Usually just more coats for finish. |
#8 posted 854 days ago |
Raymond, here is another vote for shellac but you can sand the end grain to a higher grit (if you stop at 220 for instance sand the end grain to at least 320). Sanding to a higher grit inhibits the absorption of stain/finish. -- Challenges are what make life interesting; overcoming them is what makes life meaningful- Joshua Marine |
#9 posted 854 days ago |
Scott brings up another option, although you might want to go 2-grits higher on the end grain, which would put the above example at 400-grit. Try 1-grit higher on a sample piece, and if that isn’t even enough between the two grains, then try the same experiment going 2-grits higher. -- Jonathan, Denver, CO "Constructive criticism is welcome and valued as it gives me new perspectives and helps me to advance as a woodworker." |
#10 posted 854 days ago |
Put Super Glue on the end grain.. It works for me…....just saturate, let it dry….good to go…. -- " Don't ever wrestle a pig in a mudhole....he'll be having more fun than you..!! |
#11 posted 854 days ago |
If you are staining a piece and want to keep the end grain for going darker, dilute the finish by 75% with mineral spirits for the end grain application. Put a coat on, and if required, add another. Gator -- Master designer of precision sawdust and one of a kind slivers. |
#12 posted 852 days ago |
Great tips thank everyone. -- Ray |
#13 posted 852 days ago |
Cedar is a sponge, lol. Anyway, I just toured a local high-end custom furniture outlet and they put three coats of finish on their end grains before any goes on the flat surfaces. -- Power tools put us ahead of the monkeys |
| Forum | Topics |
Woodworking Skill Share
8798 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1538 |
3556 |
15816 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2847 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2742 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6166 |
