Some help integrating jig hardware into a music stand
Forum topic by CharlesA posted 09-03-2017 08:42 PM 672 views 1 time favorited 13 replies Add to Favorites Watch
View CharlesA's profile
CharlesA
3351 posts in 2003 days
09-03-2017 08:42 PM
Topic tags/keywords: jig question
I’m going to make a music stand similar to this one:
I’m curious about your take on the hardware. I want to understand how this one works in order to figure out how I might design a mechanism.
It looks to me like they’ve mill brass for the mechanism: a slight dado so that it provides a track to slide over the t-track and then two pieces of brass screwed into the track piece. That sound right?
I haven’t tried milling brass, but I hear you can do it with woodworking bits provided you take very small cuts and are very careful. Thoughts?
13 replies so far
View Loren's profile
10477 posts in 3853 days
#1 posted 09-03-2017 09:19 PM
Another option you might consider is corian.
It’s easier to cut than brass and pretty sturdy.
Brass can be worked with power tools. You
can buy it in different hardnesses. I usually
use aluminum or corian instead for durable
small parts because both are cheaper and
easier to cut. Brass sure looks nice though.
Ebony or other hard, tight-grained exotics
also work well for moving parts. Even hard
maple.
View patcollins's profile
patcollins
1687 posts in 3071 days
#2 posted 09-03-2017 09:21 PM
That music stand is beautiful except for the plastic and anodized aluminum woodworking shop hardware on it.
I think the idea above about using a very hard tight grained wood would look much nicer.
One thing to think about is music stands usually have quite a height adjustment to account for the musicians that sit down and the ones that stand. I am guessing that this is for someone specific though.
CharlesA
#3 posted 09-03-2017 09:21 PM
Corian. That’s interesting. I have some I’ve used for ZCIs.
CharlesA
#4 posted 09-03-2017 09:23 PM
- patcollins
Thanks. These have about 10” of height adjustment.
CharlesA
#5 posted 09-03-2017 09:24 PM
I have some jatoba scraps. That stuff is much harder than aluminum.
CharlesA
#6 posted 09-18-2017 07:42 PM
It s easier to cut than brass and pretty sturdy.
- Loren
Loren, what adhesive do you use for Corian?
#7 posted 09-18-2017 07:49 PM
I don’t think I’ve glued it more than once.
I think I used super glue but I also used
screws. Epoxy or super glue should work
well I think. Maybe even contact cement.
Surfaces should be roughed up.
I have bought it on ebay in rectangle sections
stuffed in a flat rate box. It’s pretty cheap
that way if you don’t need larger pieces.
CharlesA
#8 posted 09-18-2017 07:57 PM
Thanks.
View papadan's profile
papadan
3584 posts in 3574 days
#9 posted 09-18-2017 07:57 PM
Charles, use hardwood for all of it. You can get a T track router bit and just use nuts and the nob handles for hardware. You could make the nobs hardwood too if you wanted. I have a bit and could make your T track for you, I have plenty of Walnut.
CharlesA
#10 posted 09-18-2017 08:04 PM
- papadan
I’ve actually already built it with several tries at the hardwood part. I have been playing with models. I am asking about the Corian simply because I want a backup to the hardwood.
papadan
#11 posted 09-18-2017 08:08 PM
I have one big piece of corian, but it is white. You’re welcome to it if you want. I would think epoxy would hold it.
CharlesA
#12 posted 09-18-2017 08:10 PM
That’s very generous. I bought a cheap piece off of eBay last night. Should have asked earlier! I have a beefier Jatoba version I put together last night that may be up for the task.
I have one big piece of corian, but it is white. You re welcome to it if you want. I would think epoxy would hold it.
- papadan
View woodbutcherbynight's profile (online now)
woodbutcherbynight
5734 posts in 2615 days
#13 posted 09-19-2017 01:51 AM
For small pieces of Corian like pens I use CA glue medium. For larger stuff I use epoxy, sometimes 5 minute sometimes 1 minute and if it is really large some 20 minute stuff a cabinet guy gave me with no brand name on the containers. (was half used)
Looking forward to seeing the finished product.
