Longest Reciprocating Saw Blade Available?
Forum topic by AZWoody posted 09-03-2017 05:40 PM 5820 views 0 times favorited 34 replies Add to Favorites Watch
View AZWoody's profile
AZWoody
1413 posts in 1422 days
09-03-2017 05:40 PM
What is the longest reciprocating saw blade you have seen for sale? I have a 12” but would like a 24”.
I have seen that Fein makes a 24” blade but it looks like the Fein blades do not match with the Milwaukee or other standard reciprocating saws that all the blades in the big box stores or amazon sells.
The more aggressive cut the better but if I have to settle for something that will cut metal, I can use it, it would just take longer to cut.
Any ideas?
34 replies so far
View MrRon's profile
MrRon
5192 posts in 3442 days
#1 posted 09-03-2017 10:26 PM
Why would you need such a long blade? the stroke of a reciprocating saw is only around an inch or two.
View Loren's profile
10477 posts in 3846 days
#2 posted 09-03-2017 10:32 PM
Buy the Fein blade and rivet or weld the
shank of a blade that will fit your saw to it.
117328 posts in 3776 days
#3 posted 09-03-2017 10:34 PM
There might be longer out there but I haven’t seen them as far as aggressive for wood there’s one called “the ugly that’s great for trimming tree limbs but will not take hitting metal
https://www.amazon.com/SKIL-94903-Reciprocating-Blade-3-Piece/dp/B000BM6D4O
Oh
I found a 24”but it is the Fein blade also
https://www.mscdirect.com/product/details/92982289
AZWoody
#4 posted 09-03-2017 11:42 PM
- Loren
That might end being what I”ll have to do. Or, possibly take a few 12” blades and join them together. I don’t need the cut to be pretty.
I have to make some cuts on stock that’s 18-20 inches wide and I only have a clearance of about 3/4” to get in there.
I was able to use the 12” blade but I still need to make deeper cuts.
Any other suggestions would be appreciated. I might try an 18” keyhole saw but I’m worried about the blade holding up. This is some thick pieces of wood I’m cutting through.
View WhyMe's profile
WhyMe
1073 posts in 1759 days
#5 posted 09-04-2017 01:49 AM
- MrRon
And what does stroke length have to do with needing a 24” blade?
19424 posts in 2055 days
#6 posted 09-04-2017 02:13 AM
How about making one out of a handsaw.
AZWoody
#7 posted 09-04-2017 03:23 AM
- firefighterontheside
The problem is a handsaw blade is too thin. A reciprocating saw blade is rather thick so it won’t bind and fold up from the high speed.
View waho6o9's profile
waho6o9
8516 posts in 2775 days
#8 posted 09-04-2017 04:11 AM
View mrg's profile
mrg
837 posts in 3198 days
#9 posted 09-04-2017 01:27 PM
MrRon
#10 posted 09-04-2017 06:54 PM
You could use a power hacksaw blade and grind the end to fit your saw, but they are expensive.
https://www.mcmaster.com/#power-hacksaw-blades/=198nhx1
#11 posted 09-04-2017 07:02 PM
Is there another way to do what ever it is you’re trying to do.? Chainsaw?Band saw? big foot circular saw?
If it’s a one time cut perhaps you could rent another tool or buy a Harbor freight tool for the same as renting.
AZWoody
#12 posted 09-04-2017 09:01 PM
Is there another way to do what ever it is you re trying to do.? Chainsaw?Band saw? big foot circular saw?
If it s a one time cut perhaps you could rent another tool or buy a Harbor freight tool for the same as renting.
- a1Jim
What I’m doing is trying to make some relief cuts in my lumber stacks where a couple boards have warped enough to raise up one side of the entire lumber pile. I have to be able to make some sacrificial cuts on those slabs to take the pressure off the stickers and let the pile lower down to level. If not, I’ll have a lot of boards that have a twist to them.
I “could” take apart the whole stack but these are stacks that are 4 foot wide and 5 foot tall and these boards that are warping are all near the bottom. They are lifting with enough force to raise one edge of the pile over an inch and a half higher than the other side.
The boards I need to cut are between 16 and 20 inches and the stickers are 3/4” tall so I need to be able to cut from one side only and in between the stickers. Reciprocating saw is about the only thing I can think of to make this cuts. A keyhole is possible but I’m not sure it’s rigid along to make a cut that long along an entire board.
View StephenO's profile
StephenO
44 posts in 2744 days
#13 posted 09-04-2017 09:33 PM
Just spitballing an idea here, but what about taking some 3/4” box steel, cut it long enough to slip alongside your stickers (one on top, one below), drill a vertical hole in each end, and then use a bolt at each end to force the warped boards back in line with the rest of the stack? Kind of like aligning a series of boards for a panel glue-up…
-- -Steve, Seattle
AZWoody
#14 posted 09-04-2017 09:36 PM
- StephenO
The stickers would break. Right now I have a 275 gallon tote full of water on top and it still won’t push it back down. I wouldn’t be able to get enough pressure with a bolt.
StephenO
#15 posted 09-04-2017 09:41 PM
- StephenO
The stickers would break. Right now I have a 275 gallon tote full of water on top and it still won t push it back down. I wouldn t be able to get enough pressure with a bolt.
- AZWoody
275 gallons of water is about 2200lbs, so that’s a LOT of pressure in those warped boards. Cutting them free could lead to some nasty surprises.
-- -Steve, Seattle
showing 1 through 15 of 34 replies
