Deep Mortises
Forum topic by chicomc posted 01-21-2011 03:25 AM 1148 views 0 times favorited 4 replies Add to Favorites Watch
View chicomc's profile
1 post in 2619 days
01-21-2011 03:25 AM
Hi All -
I am building a night stand and a table. The design I am doing uses a wedged/tusked through tenon. So both pieces can be “knocked down.”
My issue is that I want to make really clean mortises through the legs so that when the piece is taken apart the mortise is clean and neat. The legs on the night stand are 1 3/4” thick and the table is 2 1/2” thick.
I have been using a plunge router with a 3/8” dia. O.D. guide bushing and a 1/4” dia. spiral up cut bit and a 1/4” thick MDF template. However, I cannot get deep enough even on the smaller legs.
Does anyone have a method for making deep, clean mortises that will be seen from time to time?
Thanks for the help everyone!
View richgreer's profile
4541 posts in 3010 days
#1 posted 01-21-2011 03:39 AM
Mortising machine?
You can always drill deep enough holes on your drill press and clean them up with a chisel.
View spunwood's profile
1202 posts in 2772 days
#2 posted 01-21-2011 03:57 AM
Could you use a forstner bit on a drill press?
-- I came, I was conquered, I was born again. ἵνα ὦσιν ἓν
View Loren's profile
10114 posts in 3584 days
#3 posted 01-21-2011 05:04 AM
You won’t get a very deep mortise with a 1/4” bit. You can drill out the
waste and use your template to shape the mortise from each side.
Excess in the middle you can clean out with a chisel and a rat-tail
This whole thing will be easier if your mortise is in the 1/2” wide range.
View schroeder's profile
702 posts in 4061 days
#4 posted 01-21-2011 05:41 AM
Make your jig to come in from both sides of the leg – build stops that will guide the start/stop – use the same side of the leg as a reference – the mortise will line up perfectly
-- The Gnarly Wood Shoppe
